Moving from AutoCAD 2002 to AutoCAD 2014...block issues
spaulus
I am going to be moving from 2002 to 2014 within the next 2 weeks and have been having trouble with my custom menu and lisp routines in 2002. I had my menu setup with custom toolbars with flyouts to select blocks to insert. Most of the blocks ran a LISP routine that did several things, the main thing was reading the crosshairs to determine if you were in a certain isoplane then it would select the proper block for that plane.
I think I understand that maybe using a tool palette to select the blocks from might be a better way of inserting them now? I am not familiar with tool palettes, does anyone have advice on this subject?
Thanks,
Steve
