Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Junior Member
    AutoCAD 2013
    Feb 2014
    10
    Default automating block insertion
    Hi!
    I'm looking for a script that does this:
    insert block from specific (non changing) folder,
    *type in name of block*
    no rotation
    no scaling
    insert to picked point on screen
    (meaning- i only want to type the name end pick a point of insertion)
    any ideas?
    thanks a lot!
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,159
    This macro will do that, it starts the insert command, pauses for you to input the block name, asks for the insertion point, and inserts at normal scale and zero rotation.
    Code:
    ^C^C^Ci;\\1;0;
    You could also create a toolpalette with the various blocks, so you only need select the right one and then pick a point, obviously it depends on how many blocks you have.
    Junior Member
    AutoCAD 2013
    Feb 2014
    10
    thanks Steven,
    but how do I set the block's folder location?
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,159
    Add it to the support path, in tools - options - support file search path.
  5. #5
    Full Member
    JGA's Computer Details
    Win7
    AutoCAD 2014
    Jul 2007
    Scotland
    77
    I think a toolpallete would be the simplest answer, you wouldn't have to add a folder to the support path.
  6. #6
    Super Member Tuns's Avatar
    Tuns's Computer Details
    Windows 7 (64-bit)
    Intel Core I3-2120
    4.0 GB
    AutoCAD LT 2014
    Jun 2013
    San Antonio, Texas
    784
    Or you can just add the file path to the macro.
    Never argue with an idiot. He will drag you down to his level and beat you with experience.
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,600
    2nd go down the tool palette path or a menu or old fashioned like me.
  8. #8
    Junior Member
    AutoCAD 2013
    Feb 2014
    10
    Thank's again for all of your advice!
    I'd rather just type the serial No. ,then trying to find it in the tool-palette
  9. #9
    Junior Member
    AutoCAD 2013
    Feb 2014
    10
    Hello again!
    I have a follow-up challenge here-
    the command works great on simple blocks, but It won't insert any block inside the requested block, even when they are both in the same folder...
    any ideas?
  10. #10
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,159
    It should work, check that you don't have conflicting names or layers, if you can't see anything obvious then try posting the files here for someone to check for less obvious causes
  1. Block insertion routine based on part block file name
    By legg1979 in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2013, 06:02 pm
  2. Block Insertion
    By Squirltech in forum AutoCAD General
    Last Post: 9th Sep 2012, 12:40 pm
  3. Insertion of block
    By au-s in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Feb 2009, 12:15 pm
  4. Node at insertion of a block
    By Tunnelrat in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jan 2009, 03:30 pm
  5. Block Insertion Failed
    By Cad64 in forum AutoCAD Drawing Management & Output
    Last Post: 7th Mar 2008, 06:25 pm
Tags for this Thread
