fitzj Posted February 18, 2014 Share Posted February 18, 2014 I am doing a drawing of a a frame which is 1200mm by 600mm by 150mm deep. The frame needs to be splayed so it fits in the corner of the room. When completed only 50 mm depth of the frame will be shown the other 100mm should follow the angel of the wall splayed. What is the best way to work out these angles for a nice fit. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 I saw your post yesterday and would have responded but I was a bit confused as to what you were looking for. Did you eventually solve your problem? If so could you post an image? I'd like to see what you came up with for a solution. Thank you. Quote Link to comment Share on other sites More sharing options...
fitzj Posted February 19, 2014 Author Share Posted February 19, 2014 Quote Link to comment Share on other sites More sharing options...
fitzj Posted February 19, 2014 Author Share Posted February 19, 2014 I have uploaded a picture and it should appear soon. I presume 2 will be 90degree's and the other 1 will be 45degrees? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 No image to be seen as of yet. Is this a 3D drawing? Quote Link to comment Share on other sites More sharing options...
fitzj Posted February 19, 2014 Author Share Posted February 19, 2014 The moderator seems to control pictures? That is the message I got. Isometric drawing. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 What file format was used? Maybe it's your use of the word "splayed" that's throwing me off. Can't quite picture what you mean. Suggestion: Do it all (wall and frame) as a 3D solid model then use ViewBase command to generate the 2D isometric view. Quote Link to comment Share on other sites More sharing options...
fitzj Posted February 19, 2014 Author Share Posted February 19, 2014 I am a beginner I have no idea how to do what you requested sorry. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 Why don't you attach a drawing of what you have so far so we can take a look at it. You do have the frame drawn in top and front views don't you? Quote Link to comment Share on other sites More sharing options...
fitzj Posted February 19, 2014 Author Share Posted February 19, 2014 Not sure how this works doing a test with attachment. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 The angles have to add up to 180 degrees. Looks like the frame would be 45 degrees to the wall so the other angle would be......? I bet you know. Quote Link to comment Share on other sites More sharing options...
fitzj Posted February 19, 2014 Author Share Posted February 19, 2014 Many thanks ReMark for sticking with me on this. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 Is this what you had in mind? Quote Link to comment Share on other sites More sharing options...
