Pakowano Posted February 18, 2014 Share Posted February 18, 2014 Hello, I'm trying to make blocks with attributes and i watched video on youtube to do so .But when I insert the same block I need to name the tags twice. I don't know how it happens and it bugs me. Please help! A second question is that when I load the block in another dwg file, the base point isn't the same as it was on the existing file. how does this happen and how can i reset the point? and please use simple words because I'm from the Netherlands and I only know basic English:( thank you very much, Pakowano Quote Link to comment Share on other sites More sharing options...
steven-g Posted February 18, 2014 Share Posted February 18, 2014 Can you post the block, someone could check it out and see what is going on. En welkom op het forum Quote Link to comment Share on other sites More sharing options...
Pakowano Posted February 18, 2014 Author Share Posted February 18, 2014 Can you post the block, someone could check it out and see what is going on. En welkom op het forum how do i do this? Hoe doe ik dit Quote Link to comment Share on other sites More sharing options...
Pakowano Posted February 18, 2014 Author Share Posted February 18, 2014 aaah that's how Onderhoek.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted February 18, 2014 Share Posted February 18, 2014 You have the attribute set-up to ask you to confirm your details, turn off verify in the attribute properties, and if you have any attributes that have a fixed value you can turn preset to 'yes' that way it won't prompt you for the value when you insert the block. The insert point looks good, I didn't get a problem, just make sure the tick box for 'insertion point on screen' is selected in the insert dialogue. Quote Link to comment Share on other sites More sharing options...
macmini706 Posted February 21, 2014 Share Posted February 21, 2014 Hi thank you I like it Quote Link to comment Share on other sites More sharing options...
