+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Senior Member
    Using
    not specified
    Join Date
    Aug 2003
    Location
    Richmond, Va.
    Posts
    150
    Default Copy between Layers
    I'm probably trying to do something differently than Autodesk wants me to, or using the wrong terminology.
    In Generic CADD & Power CADD I used to do 2 or 3 story building plans in one file, with a set of layers for each story. I could copy lines & other objects from one layer to another layer to draw another story.
    I haven't been able to figure out how to do this directly in AutoCAD. The least bad method I have come up with is to use CO to copy the lines & other objects I want and offset them, select them and use the Properties window to change the layer, then finally move them all back into position.
    Is there a less tedious way to do this?
  2. #2
    Flores
    Default
    Use the "copytolayer" of the Express Tools. Start the command, select your objects > enter > Specify destination layer in dialog box > OK > for prompt "Base point or <return> to finish:" just hit enter to copy to exact same location.
    Flores
Posting Permissions
  • You may not post replies
  • You may not edit your posts
