Spiral Pattern of Points
cowpoke
Using Inventor 2012 I would like to create a spiral pattern of points where I can control the spacing. For example .625 spacing between each point and also between each spiral ring out to a specified diameter. The pattern would then be used to create a jewled pattern on a piece of sheet metal.
Appreciate any help anyone can provide.
