brow_tines Posted February 23, 2014 Share Posted February 23, 2014 In AutoCad if you want to draw a line 6" you click the line command and hit "6" how can I change Inventor to do this? I have to draw a line and then dimension it. I'm using Autocad Inventor 2013 Student Edition. Thank you Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 23, 2014 Share Posted February 23, 2014 Should be exactly the same in Inventor. Have you fooled with the default settings? http://home.pct.edu/~jmather/skillsusa%20university.pdf Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 23, 2014 Share Posted February 23, 2014 I always thought that in Inventor you draw a cocktail napkin sketch of your object throw some dimensions on it (parametrically speaking) and the program does the rest. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 23, 2014 Share Posted February 23, 2014 Either way. Many users want to use the same AutoCAD techniques that they are familiar with (direct distance entry) in Inventor. Quote Link to comment Share on other sites More sharing options...
Bishop Posted February 24, 2014 Share Posted February 24, 2014 I always thought that in Inventor you draw a cocktail napkin sketch of your object throw some dimensions on it (parametrically speaking) and the program does the rest. Look, you're not supposed to TELL people about that. If everyone realized it was that easy, how would we be able to justify making the medium bucks? Quote Link to comment Share on other sites More sharing options...
ecshclark Posted February 24, 2014 Share Posted February 24, 2014 H'mm, so these forums are why I haven't received any large raises in years. Too many people, knowing too much. Just don't let anyone know the technique that allows Inventor to read your thoughts. It's the only thing I've got left to justify my existence. Although, they still haven't fixed that bug where is doesn't know if you are thinking 6 millimeters, or 6 inches! Quote Link to comment Share on other sites More sharing options...
