Results 1 to 4 of 4
    Junior Member
    david1-b's Computer Details
    Windows 7
    Surveying
    david1-b's Discipline Details
    I work on problems and annoyances around the office
    Surveying
    Civil 3D 2013
    Nov 2012
    Canada
    14
    Default Add bend to leader lines
    Hello,
    I am trying to add a bend to my leader lines using Civil 2013. I have attached two images the first one is of my standard leader (dimension is inline with the leader line), the second one is a leader I "faked" to illustrate my desired leader style, a perpendicular leader then a bend to some text. Does anyone know how a leader like this can be made. In this example I am using a dimension, but I would be happy with a solution that used multileader.
    Thanks
    If any clarification is required please ask
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    You cannot make a multileader including the extension lines and the other opposite arrow. but you can make one that looks like the leader to the right of the rightmost extension line.
    Create a new multi-leader style with a straight leader,
    3 maximum points,
    first segmrnt angle = zero,
    second segment angle = 45 deg,
    Uncheck - Automatically include landing AFTER setting landing length to zero,
    Content tab = for the leader connection set both the left and right attachments to bottom of bottom line.
    When you set the mleader into your drawing, you will click on where you want the arrow, slide the cursor to the left or right, click where you want the bend to start, slide the cursor in an approximately 45 deg direction and click the text position, type the text, then hit OK or click into the blank modelspace area.
    The multileader will not know your dimension. You will have to type it in. What is the advantage in using a multileader instead of a dimension? How will you insure that the dimension is correct? What happens after modifications? Associative dimensions correct themselves.
    The other alternative is to create a dynamic stretching block with a text attribute.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Junior Member
    Windows 7
    Surveying
    Surveying
    Civil 3D 2013
    Nov 2012
    Canada
    14
    Dana,
    Thanks for the reply.
    All your points are valid, I just used a dimension for this example as it was easier to illustrate the desired output then it was with a multileader. I am looking at ways to clean up some of our labeling and am gathering ideas on built in solutions before moving towards customization. You are right if a dimension is involved a dimension box should be used, not a multileader and I think I will be looking at solutions to modify both dimension leaders and multleader leaders to get my opposing arrows and kinked leader line.
    Unless you have any additional advice, I would mark this post as answered but I can't seem to see a way to do that.
    Thanks
    David
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Quote Originally Posted by david1-b View Post
    Dana,
    Thanks
    David
    There is a way to force the dimension arrows and text outside of the extension lines, but only when they don't fit between the extension lines. Also, you can manually relocate the text with a leader, but the leader stays attached to the center of the dimension line, and neither of the arrows are on the leader. That is not exactly what you were looking for. I don't know of other mods that might be available in the dimension style editor. If you find a way, let us know.
    Yeah, the threads don't get marked here. A courtesy response from the OP like you did is really cool though. Thanks for that.
  1. Replies: 0
    Last Post: 5th Apr 2012, 08:15 pm
  2. Bend lines while constraining dimension
    By edwardw in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Apr 2008, 05:48 am
  3. Spiral shaped web, how to bend lines and unify
    By Endoskeleton in forum AutoCAD General
    Last Post: 12th Jul 2007, 04:28 pm
  4. Soldraw showing bend lines?
    By WagglyFawn in forum AutoCAD Drawing Management & Output
    Last Post: 8th Jun 2007, 03:43 pm
  5. Removing bend lines & centermarks
    By CycloneTS in forum AutoCAD General
    Last Post: 23rd Mar 2005, 10:23 pm
Tags for this Thread
