Results 1 to 7 of 7
    Junior Member
    david1-b's Computer Details
    Windows 7
    Surveying
    david1-b's Discipline Details
    I work on problems and annoyances around the office
    Surveying
    Civil 3D 2013
    Nov 2012
    Canada
    14
    Default Perpendicular multileader advice
    Hello,
    This is outside my normal LISPing and I am in need so some advice.
    My goal is to create (or modify) a multileader leader and landing line so they can be used to add perpendicular leaders to opposing sides of drawing features, as seen in the attached image. The reason for this is to improve the clarity of labeling (by having an additional leader style. I am not sure if this can be completed via LISP or a .net approach must be taken. Can anyone provide any advice?
    Thanks
    David
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    FWIW -
    Your 'desired multileader' is also known as a dimension; I say that as a LISP & .NET developer adept with MLeader Typed Objects.
    The issue is that the end of the upper leader is in the opposite direction, and not connected to the actual MLeader itself. This is simply not possible via MLeader AFAIK. You can code an Object Reactor that would give the illusion of a Leader being bound to an MLeader, but would be indeterminably complex, and would only work for you (if the code behind was also loaded).
    The only other non-Dimension related option potentiality I can think of is to implement the same objects noted previously via geometric constraints... Again, unnecessary complexity, when you could just tailor an OOTB Dimension Style.
    HTH
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    Junior Member
    Windows 7
    Surveying
    Surveying
    Civil 3D 2013
    Nov 2012
    Canada
    14
    Thanks a lot for the reply,
    I was short on ideas on how to create the leader that is not connected to the text. I actually started with the dimension option, but as I was originally asked about a means of modifying our multileader I thought I would ask as a dimension and a multileader are not a 1:1 replacement. I see how the dimension can complete my goal, but I am unsure of how well the idea would go over of changing from labeling with multileaders to labeling with custom dimension blocks.
    Thanks
    David
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    No worries; the only other alternative I can think of, is to use a simple to moderately complex dynamic block, which might afford you the flexibility you're after. It would easily support the ability to 'stretch' your arrow placement, while being linked together using OOTB functionality, and an attribute with field could serve as the dimension aspect of the label.
    That should have been in my original post, but I only now thought of it, as I don't use many dynamic blocks for my work with C3D these days.
    HTH
  5. #5
    Full Member
    AutoCAD 2013
    Dec 2012
    53
    I have used this for a long time and it worked pretty good!
    (the first program: how do I link a leader to an object)
    It is freeware (and no I am not advertising).
  6. #6
    Junior Member
    Windows 7
    Surveying
    Surveying
    Civil 3D 2013
    Nov 2012
    Canada
    14
    Great,
    I have a lot of options to follow up on and appreciate all the ideas. Even if you were advertising (and it was the solution) I would not mind .
    David
  7. #7
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    I say go with both. When labeling such areas as easement lines, if the two lines are parallel, and large enough apart that an mleader with more than one arrow would look a little messy, I will add an aligned dimension, edit to include whatever additional text I may need, and go on with my business. As long as your MText, Dimension, Mleader styles (text, arrows) all match, no one will ever look at it and wonder why you suddenly decided to use a dimension rather than an mleader to label something. Hell, I recently had a building with several service doors (4 along each wall). I drew the extents of each service door, and then put in one aligned dimension from the farthest two ends of the 4 service doors, and then changed the text from the dimension length to say "Service Doors". It gave me a set of arrows pointing out what I was trying to label, it was parallel to the wall, and it looked nice.
    Now that I've typed all that, I could have just shown a screenshot...if I wasn't too lazy to recreate.
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  1. perpendicular from a line
    By Nina in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Oct 2012, 05:10 pm
  2. Perpendicular snaps
    By Valce in forum AutoCAD Beginners' Area
    Last Post: 24th Jun 2008, 10:02 pm
  3. Ucs non perpendicular
    By sportiveSE in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Feb 2008, 09:45 pm
  4. perpendicular from..
    By mikemilburn in forum AutoCAD Beginners' Area
    Last Post: 15th Jul 2007, 02:41 am
  5. Perpendicular to what?
    By willwould in forum AutoCAD Beginners' Area
    Last Post: 13th Oct 2006, 01:51 pm
Tags for this Thread
