Results 1 to 6 of 6
    Forum Newbie
    AutoCAD LT 2012
    Mar 2012
    Pullman, WA
    5
    Default Combine lsp routine
    I am using ACAD 2013. I am new to using lsp files. Is it possible to combine 3 lsp routines that I regularly run to prepare files for a different software program? Is it possible to use the combined lsp routine to batch process multiple files in a folder? Is it possible to modify the 1st code to open the new file automatically?
    Code:
    ;changes layout to model space, appends filename, option to open new file
    (defun c:L2M ( / BASE LST OLD_DIA)
      (setq old_dia (getvar 'FILEDIA)
     base (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME)))
      (setvar 'FILEDIA 1)
      (setq lst (layoutlist))
      (foreach l lst
        (command "_.ctab"
          l
          "exportlayout"
          (strcat base "-" l)
      (setvar 'FILEDIA old_dia)
    Code:
    ;Sets linework to by layer, layers to color 7 white, detaches external references
    (defun c:set7 ()
    (setq uecho (getvar "cmdecho"))
    (setvar "cmdecho" 0)
    (command "setbylayer" "al" "" "n" "y")
    (command "-layer" "c" "7" "*")
    (command "-xref" "d" "*")
    (setvar "cmdecho" uecho)
    Code:
    ;Justify text
    (defun c:BL (justify title / ss)
      (princ (strcat "\nSelect *Text to " title " justify: "))
      (if (setq ss (ssget "_:L" '((0 . "ATTDEF,MTEXT,TEXT"))))
        (command "_.justifytext" ss "" justify)
    (defun c:JL (/) (_justifyIt "_ML" "Middle Left"))
    (defun c:JC (/) (_justifyIt "_MC" "Middle Center"))
    (defun c:JR (/) (_justifyIt "_MR" "Middle Right"))
    (defun c:BL (/) (_justifyIt "_BL" "Bottom Left"))
    (defun c:BC (/) (_justifyIt "_BC" "Bottom Center"))
    (defun c:BR (/) (_justifyIt "_BR" "Bottom Right"))
    (defun c:TL (/) (_justifyIt "_TL" "Top Left"))
    (defun c:TC (/) (_justifyIt "_TC" "Top Center"))
    (defun c:TR (/) (_justifyIt "_TR" "Top Right"))
    I don't know who the code authors are to give credit.
    Senior Member
    Snownut's Computer Details
    Windows 10 Home premium
    Lenovo
    not applicable
    Nov 2010
    New Hampshire
    238
    tamipeab,
    #1.-Please use code wrapper when posting code.
    #2.- Since all your lisp functions are defined as "c:..." you can place them all in one lisp file to load all at once.
    Forum Newbie
    AutoCAD LT 2012
    Mar 2012
    Pullman, WA
    5
    What is code wrapper? I've tried combining them but I don't know enough about lsp writing to make it work.
    Senior Member
    Lenovo
    not applicable
    Nov 2010
    New Hampshire
    238
  5. #5
    Senior Member mostafa badran's Avatar
    mostafa badran's Computer Details
    win 7
    Dell
    Core I7
    12 GB
    2 GB
    350 GB
    Fujitsu
    Electrical
    mostafa badran's Discipline Details
    Cad Operator
    Electrical
    Power & low current system.
    AutoCAD 2014
    May 2010
    KSA
    233
    Open New Text Document.txt and change extension from .txt to .lsp then
    copy your lisps, past them in the New Text Document.lsp then close and save your lisp.
    What doesn't kill you makes you stronger
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    Easy way is to use a script can open and close as many as you like and run multiple lisps in the process.
    Code:
    open dwg1
    (load "lisp1")
    (load "lisp2")
    close y
    open dwg2
    (load "lisp1")
    (load "lisp2")
    close y
    and so on
  1. combine 2 or more dwg in one
    By hosyn in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jul 2014, 05:10 am
  2. Combine three lisp routine into one routine.
    By BrianTFC in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Feb 2012, 05:11 pm
  3. combine xref to dwg
    By sparkyuk in forum AutoCAD Beginners' Area
    Last Post: 23rd Oct 2009, 05:52 pm
  4. Combine IF
    By FazBear in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th May 2009, 10:11 am
  5. How can I combine 4 drawings into 1?
    By BOB'27T in forum AutoCAD Drawing Management & Output
    Last Post: 6th May 2008, 05:50 pm
Tags for this Thread
