Redcorded Macro to shortcut key
Nobull84
I'm just learning how to utilize recordable macros. I have a simple one that I found how to assign to a tool palette by simply changing the properties command string to "^C^CBottom" and "^C^CTop". These are the titles of the macros I created. The article I found explaining this said you can also assign a shortcut key using the aliaseditor but it does not recognize it as a valid command. Is there a way to either use the aliaseditor or the CUI to assign a shortcut for these recoded macros?
Thanks,
-Nobull
And of course I figure it out after asking the question. Create new command with the string above and drag it to keyboard shortcuts. Maybe I just needed to type it out to see it? :?
-Nobull
