Agapi Posted March 3, 2014 Share Posted March 3, 2014 Hey everyone, i am new here. I am new to autocad and needing help... i made a circle because i am trying to make an auditorium and i am trying to find 0.5590 degrees but i can not... basicaly i need to divide the circle into eaqual pieces Please have a look in the image. Does someone know how can i do that?? Thank you very much!!! Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 3, 2014 Share Posted March 3, 2014 First set your angle precision to four decimal places in UNITS. Then draw a line equal to the radius of your circle at an angle of 0.5590 which can be done via the command line. In the example below the length of the line representing the radius is 2. Type the input exactly as shown. Command: Line Specify first point: cen (for center of circle) Specify next point or [undo]: @2.0 Quote Link to comment Share on other sites More sharing options...
Agapi Posted March 3, 2014 Author Share Posted March 3, 2014 I tried but I had no result maybe because I do not know how to draw @ point. Is there any other way that I can make the angle without the @point?? Quote Link to comment Share on other sites More sharing options...
Dana W Posted March 3, 2014 Share Posted March 3, 2014 Once you have your precision set high enough, you can polar array your circle into equal chunks. Even at a 100 foot radius this angle is only going to give you about 12" between points on the circumference of the circle. Quote Link to comment Share on other sites More sharing options...
