Export layout from many dwg file
wrha
layouts in separate files to separated dwg ?
I'm a little confused if the original layouts are in one file and need to be separated or in more than one file and need to be collated into one.
If the former, then do what Mircea suggests.
If the latter, you can copy a layout from another drawing using right click on the layout tab, "from template", select a dwg file instead of a dwt.
At first I thought that I understood your query, but after Cwake's post I realized that unfortunately isn't very clear. I'm still not sure what to understand.
Please clarify, which of the diagrams below is true:
many layouts in separated files export to model space in separated file (like export option in autocad but for many layout) because i have huge no. of separated shop drawings i need extract the lay out with no xref
  • 1 month later...
