Results 1 to 4 of 4
    Forum Newbie stiebert's Avatar
    AutoCAD LT 2014
    Jul 2013
    2
    Default Picking a station along a curve - AutoCAD
    I have a paper plan set of a sidewalk that contains several simple horizontal curves. I've managed to use the curve data to replicate the sidewalk centerline in my CAD file. The outside edge of the sidewalk is kind of a zig-zag polygon line. To locate change of direction corners in the zig-zag line I was given the location point as a station along the trail and offset distance from trail centerline. My question is how do I easily locate a point along the curve at a specified station.
    I've managed to do a few using the MEASURE command and I insert a block at the specified station as a distance from the point of curvature. This works, but is very cumbersome and on top of that every time I insert the block it inserts 4 of them at the specified length that I entered.
    Please let me know if anyone has a quicker method. Also, if you know how to fix my problem with the MEASURE command I would appreciate that as well.
    Thanks,
    Senior Member PEGAdevelopment's Avatar
    Civil
    PEGAdevelopment's Discipline Details
    Engineering Drafter/Designer
    Civil
    Revit MEP 2015
    Jun 2013
    TEXAS
    106
    I would make an alignment from the centerline. Next use the annotate tab, click "add labels", select "alignment" and choose "station offset" and take it from there.
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    924
    Quote Originally Posted by PEGAdevelopment View Post
    I don't think LT has Alignments or station offset commands.
    Murph
    Need a boat or camper for the weekend?
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,042
    If its intersection pt relative to a curve then just draw a line from pt "Perp" to arc thats the true pt.
  1. Down load leica total station to autocad
    By NHOJ in forum AutoCAD General
    Last Post: 30th May 2013, 11:43 am
  2. Problem with picking fonts from MS office in AutoCAD MEP 2010
    By Rathaur in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Aug 2012, 10:40 am
  3. Transfer AutoCAD 2012 points to Carlsen Handheld Device for Total Station
    By jpetgarney in forum AutoCAD Drawing Management & Output
    Last Post: 8th Sep 2011, 05:47 pm
  4. AutoCad Work Station
    By zilincik in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2008, 03:43 pm
  5. Replies: 1
    Last Post: 15th Feb 2008, 07:21 am
Tags for this Thread
