Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: draw arrows
    Junior Member
    not specified
    Aug 2006
    11
    Default draw arrows
    brand new user to CADD..using AutoCADD 2006...
    ok, this has got to be easy...a co-worker once showed me how to draw arrows for directional purposes on our drawings (essentially maps), but i can't remember how she showed me and she is no longer here. how do i draw arrows?
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,429
    Try using the LEADER command.
    You can also create arrows using the PLINE command and specify your starting width as 0 and your ending width as 1 and then drag it out so the proportions look right.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
    Junior Member
    not specified
    Aug 2006
    11
    when i tried the LEADER command it would only draw straight lines and 90 degree angles...i was unable to make the triangle portion of my arrow...is there a setting i need to change or something else in the command i need to input?
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    3ds Max 2011
    Feb 2006
    Southern California
    8,429
    You have to set up a dimension style and specify the type of arrowhead you want to use as well as what size you want the arrowhead to be.
  5. #5
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 7
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    1TB
    Portable TB drive
    Samsung SyncMaster 226
    Inventor 2013
    Aug 2005
    Northants, England
    1,565
    hit F8
    USING AUTOCAD 2013 AND INVENTOR 2013, ALIAS 2013.
    If in doubt scale and don't ask!
  6. #6
    Junior Member
    not specified
    Aug 2006
    11
    ok, Cad64 yours was a little more complicated and since i don't know where to create those settings i went with deelay's suggestion. (sorry, i have 0, zilch, nada experience with CADD - this was dropped in my lap)...
    deelay: i hit F8 and that worked to create my angles...quick questions, after it is drawn on the screen, the line attached to the cursor keeps following me and i want it to stop once i create the arrow. also, after it is created is there an easy way to fill it in with color?
  7. #7
    Senior Member Jamalama's Avatar
    Civil 3D 2010
    Mar 2005
    Colorado, USA
    157
    to fill the arrowhead go to the draw pulldown menu>hatch>make sure the pattern is solid and click on addick points> click on the interior of the arrowhead
    Life comes down to 4 letters...PRFF
    Pride Respect Friends Future
    The Rest is Just Filler
  8. #8
    Junior Member
    not specified
    Aug 2006
    11
    i'll give that a try first thing Monday...thanks for the suggestion...
    also, how do i make sure the pattern is solid? i try my best, but how do i make sure?
  9. #9
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    3ds Max 2011
    Feb 2006
    Southern California
    8,429
    You cannot fill the leader arrowhead with a hatch pattern. You need to create a dimstyle as I suggested before.
    Type DIMSTYLE at the command prompt to open the Dimension Style Manager. The current dimstyle will be highlighted, so click the New button to create a new dimension style. You will now be allowed to name the new dimstyle, so name it something like Dimleader or whatever and click Continue. Now select the "Symbols and Arrows" tab and change the Leader setting to Closed Filled. You can also change the Arrow Size here if you need to. Click Ok to save your changes. Now make sure your new dimstyle is highlighted and click the Set Current button and then close the Manager.
    If you just want to draw a solid filled arrow with a tail and nothing else, start the LEADER command and then type S for Settings. This will open the "Leader Settings" dialog. On the Annotation tab, under "Annotation Type", select None. On the Leader Line and Arrow tab, under "Number of Points", set the maximum to 2. Now click ok to exit the Leader Settings dialog.
    Now go ahead and draw a leader. Click once to start the leader and a second time to end the leader. You should get a solid filled arrowhead with a tail and nothing else.
  10. #10
    Senior Member zars's Avatar
    zars's Computer Details
    Windows Xp Profesional Service Pack 3
    Dell Optiplex 755
    Intel D946GZIS
    Intel Core2Duo 2.13 GHz
    1 GB Kingston DDR2 333 Mhz
    Sata 300 Gb Western Digital
    Dell 17''
    AutoCAD 2007
    May 2006
    LZC, Michoacan, Mexico.
    464
    He also can draw the line and the arrowhead with polyline or line command (so far I understand he already did it) and then he can fill it with hatch command, to make sure the pattern is solid, try with "bhatch" or simply type in "bh" and it'll show you the patterns, then just click on pick points and select a point inside your arrowhead and it should be enough.
    There are only 2 things which are infinite... the universe and the human stupidity.
    "Life is not the amount of breath you take, it's the moments that take your breath away"
