Jessica28 Posted March 7, 2014 Share Posted March 7, 2014 I'm running autocad MEP 2014. I was for a lisp routine that'll add the quantity of pieces of text in a drawing. All my posts lately have been about adding something.....Basically I have drawings with multiple pieces of text in them. the number 20 written hundreds of times. the number 25 written hundreds of times, and so on....I'm not looking for a routing that totals them up, but a routing that'll tell me how many instances there are of each.....Right now I go to properties, then quick select, then I select text, I click on contents and then I put in a value....And I do this for every number. That's a lot of work. Is there a routine that can simplify this process? Or maybe cad can do it with a command that already exists that I don't know about? Thanks, Jess Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 7, 2014 Share Posted March 7, 2014 (edited) Try this UNTESTED routine and let me know . (defun c:Test (/ st ss) (if (and (/= (setq st (getstring t "\n Specify string to search for :")) "" ) (setq ss (ssget "_X" (list '(0 . "*TEXT") (cons 1 st)(cons 410 (getvar 'ctab))))) ) (progn (alert (strcat "You have < " (itoa (sslength ss)) " > of your input string " ) ) (sssetfirst nil ss)) (alert "Nothing found <!>") ) (princ) ) Edited March 7, 2014 by Tharwat Quote Link to comment Share on other sites More sharing options...
Jessica28 Posted March 7, 2014 Author Share Posted March 7, 2014 Awesome. Yes it does work.....Is there any way that the routine can be modified so that when it gives me a total it also selects them so I can move them aside and delete them and move on to the next number? The reason for this is so its easier for me to chose which number I want to count next...If its cluttered with all the other numbers that I already counted its harder to find new numbers....Ideally I'd like to select the whole drawing with a command and it would populate a total list of everything.. : ) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 7, 2014 Share Posted March 7, 2014 I modified the routine , try it and let me know . Quote Link to comment Share on other sites More sharing options...
Jessica28 Posted March 7, 2014 Author Share Posted March 7, 2014 Yes. It worked! that's great! That saves me sooo many steps...Thank you.. Hopefully next I can find something that'll do all the numbers at once. You guys keep making my job easier and easier. Lol Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 7, 2014 Share Posted March 7, 2014 Yes. It worked! that's great! That saves me sooo many steps...Thank you.. Hopefully next I can find something that'll do all the numbers at once. You guys keep making my job easier and easier. Lol Excellent , Good luck . Quote Link to comment Share on other sites More sharing options...
manohar Posted March 17, 2014 Share Posted March 17, 2014 Dear Mr.Tharwat, i am looking for a lisp to add the text. You are kind & helping lot of peoples in this forum and I hope you could help me on this. I don't know how to explain this, So i have attached a sample. Want to add the plant annotation and tabulate the results or export to txt file. Thanks Manohar. PLANTING.dwg Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 17, 2014 Share Posted March 17, 2014 (edited) Dear Mr.Tharwat, i am looking for a lisp to add the text. You are kind & helping lot of peoples in this forum and I hope you could help me on this. I don't know how to explain this, So i have attached a sample. Want to add the plant annotation and tabulate the results or export to txt file. Thanks Manohar. Something like this ? (defun c:Test (/ s i e f o x y l lst) ;; Tharwat 18. mar. 2014 ;; (princ "\n Select texts to export to txt file :") (if (setq s (ssget '((0 . "TEXT") (1 . "#*")))) (progn (setq o (open (setq f (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME)) ".txt")) "w")) (write-line (strcat "DESCRIPTION" "\t" "QTY") o) (repeat (setq i (sslength s)) (setq e (entget (ssname s (setq i (1- i)))) x (cdr (assoc 1 e)) b "" ) (while (wcmatch (setq a (substr x 1 1)) "1,2,3,4,5,6,7,8,9,0") (setq b (strcat b a) x (substr x 2) ) ) (if (setq y (assoc (setq x (substr x 2)) l)) (setq l (subst (cons x (+ (atof b) (cdr y))) y l)) (setq l (cons (cons x (atof b)) l)) ) ) (foreach x l (write-line (strcat (car x) "\t" (rtos (cdr x) 2 1)) o)) (close o) (startapp "notepad.exe" f) ) ) (princ) ) Edited March 18, 2014 by Tharwat Quote Link to comment Share on other sites More sharing options...
manohar Posted March 17, 2014 Share Posted March 17, 2014 (edited) Something like this ? Thanks for the quick response. Sorry I could not able to put what i need in thread. Current Result DESCRIPTION QTY 1 T/AZA.I 1 10 G/ALT.A 1 3 P/PHO.D 1 12 P/RHA.E 1 5 P/RHA.E 1 1 P/RHA.E 1 2 P/PHO.D 1 36 G/ALT.A 1 1 T/PLU.O 2 Desired Result DESCRIPTION QTY T/AZA.I 1 G/ALT.A 46 (36+10) P/RHA.E 18 (12+5+1) P/PHO-D 5 (3+2) T/PLU.O 2 (1+1) Edited March 18, 2014 by manohar Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 18, 2014 Share Posted March 18, 2014 I updated the codes above , try it and let me know . Quote Link to comment Share on other sites More sharing options...
manohar Posted March 18, 2014 Share Posted March 18, 2014 I updated the codes above , try it and let me know . Wow. Working Great. I really apprecaite your help. it is going to save lot of my time. Thanks a Lot. Manohar Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 18, 2014 Share Posted March 18, 2014 Wow. Working Great. I really apprecaite your help. it is going to save lot of my time. Thanks a Lot. Manohar Excellent , You're welcome Manohar and I am happy to help. Quote Link to comment Share on other sites More sharing options...
