Alert needed while opening CAD file
dreams
Can someone help me to fix this issue?
Is it possible to set an alert (with using particular text in inside the CAD file) while opening CAD files each time?
Example: The alert will be “You have used IBM in this drawing”, if we have a text noted as “IBM” inside the CAD file.
  • Replies 22
  • dreams
    12
  • Tharwat
    7
  • MSasu
    3
  • fixo
    1
One example for text/mtext entities in active tab - should be placed in a start-up resource (i.e. acaddoc.lsp):
(setq ssText (ssget "_X" '((0 . "*TEXT"))))
(while ssText
(if (wcmatch (cdr (assoc 1 (entget (setq entTemp (ssname ssText 0))))) "*IBM*")
 (setq ssText (alert "You have used IBM in this drawing!"))
(setq ssText (ssdel ssText entTemp))
This may be extended to verify all tabs, support other entities or check for a list of words.
Hi MSasu/Tharwat..Thanks...
I have added in that lisp file (acaddoc.lsp)...but its not working...I am not familiar in lisp settings..Please help me...
Please check the tutorial from my previous post to create an user auto-loader. Isn't a good practice to use the system one (acaddoc20##.lsp) since may be overwriten, so may want to avoid this.
Also, you will need to add only one solution there to don't get two warnings in a row; I suggest to use Tharwat's one since is faster.
  • 8 months later...
Hi Tharwat,
I need your help again. Is it possible to add a list of different texts for Alert while opening CAD file? Please refer my sample notes..
1.The text is IBM - Alert should shown as "You have used IBM in this drawing"
2.The texts are Coupler/Thread/Threading/Threaded/Threading – Alert should shown as “You have used COUPLER/THREADED BARS in this drawing
3.The texts are Form savers/End preparation - Alert should shown as “FORM SAVERS are used"
The code is below,
(if (ssget "_X" '((0 . "*TEXT")(1 . "IBM")))
  (alert "You have used IBM in this drawing")
FYI, I will have to add more text alert in future...
Show me the way you are feeding your strings and functions , to allow me and the other users to know how to make it work for you and try to give you the best solution .
I am not familiar with lisp codes..
Here is the below code details which i tried...
((setq ssText (ssget "_X" '((0 . "*TEXT"))))
(if (ssget "_X" '((0 . "*TEXT")(1 . "COUPLER")))
  (alert "You have used COUPLER/THREADED BARS in this drawing")
(if (ssget "_X" '((0 . "*TEXT")(1 . "Form savers")))
  (alert "FORM SAVERS are used")
(if (ssget "_X" '((0 . "*TEXT")(1 . "coupler")))
  (alert "You have used Coupler in this drawing which we have to provide separate material list")
(if (ssget "_X" '((0 . "*TEXT")(1 . "THREAD")))
(if (ssget "_X" '((0 . "*TEXT")(1 . "THREADING")))
Try this .
(if (setq ss
          (ssget "_X"
                 '((0 . "*TEXT")
                   (1 . "IBM,COUPLER,Form savers,coupler,THREAD,THREADING")
     (setq st (cdr (assoc 1 (entget (ssname ss (setq i (1- i)))))))
     (if (not (member st lst))
       (setq lst (cons st lst))
   (if lst
       (setq l (vl-remove-if-not
                 '(lambda (u) (member u lst))
                 '("IBM" "COUPLER" "Form savers" "coupler" "THREAD"
                   "THREADING"
       (alert
         (strcat
           "You have used < "
           (substr (setq s (apply 'strcat
                                  (mapcar '(lambda (x) (strcat x ",")) l)
                   1
                   (1- (strlen s))
           " > in this drawing"
 (alert
   "Couldn't find any of these strings < IBM,COUPLER,Form savers,coupler,THREAD,THREADING > in drawing "
Hi Tharwat, i have an issue while using this lisp, It's not finding the text in the combined sentences. Example: Male Coupler at one End
FYI, It's finding only separate text only.
have you got my point?
Do you have any suggestion on this??
