danielk Posted March 16, 2014 Share Posted March 16, 2014 (edited) tried to disable those reg values "EnableCommunicationCenter", "EnableNonPatchNotifications" and "MaintenancePatchNotificationOption" to 0 (zero). tried to rename WSCommCntr4.exe (located here: C:\Program Files\Common Files\Autodesk Shared\WSCommCntr4\lib) to something else , but its still pop ups . Anyone have a solution ? Thanks Edited March 16, 2014 by danielk Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 16, 2014 Share Posted March 16, 2014 Owen Wengard posted a .msi file that takes care of the problem. I just included a link to a site where it could be downloaded recently. Try searching on "CommCenter". Quote Link to comment Share on other sites More sharing options...
danielk Posted March 24, 2014 Author Share Posted March 24, 2014 Owen Wengard posted a .msi file that takes care of the problem. I just included a link to a site where it could be downloaded recently. Try searching on "CommCenter". I Tried (http://otb.manusoft.com/2010/11/disable-autocad-infocenter.htm/comment-page-1) isn't working for 2014 Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 24, 2014 Share Posted March 24, 2014 Open the Windows Task Manager and click on the Processes tab. Scroll down to the bottom of the list until you find the entry WSCommCntr4.exe and kill it. Close Task Manager when you are done. The CommCenter is also known as the InfoCenter. Take a look at this from AutoDesk...http://knowledge.autodesk.com/support/autocad-architecture/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-disable-the-Communication-Center-in-Autocad-s.html Quote Link to comment Share on other sites More sharing options...
danielk Posted March 24, 2014 Author Share Posted March 24, 2014 Open the Windows Task Manager and click on the Processes tab. Scroll down to the bottom of the list until you find the entry WSCommCntr4.exe and kill it. Close Task Manager when you are done. The CommCenter is also known as the InfoCenter. Take a look at this from AutoDesk...http://knowledge.autodesk.com/support/autocad-architecture/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-disable-the-Communication-Center-in-Autocad-s.html Each startup it will run again . so this is not a good option Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 24, 2014 Share Posted March 24, 2014 The Wengard .msi fix should have worked on your version of AutoCAD. If it didn't then these are the only other fixes I know of. Quote Link to comment Share on other sites More sharing options...
