WPerciful Posted March 18, 2014 Share Posted March 18, 2014 If I use our stb to plot to our printer, the print looks right. If I plot it using “DWG To PDF.pc3” the lines are lighter. Any suggestions? I can switch to using ctb's instead. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted March 18, 2014 Share Posted March 18, 2014 Did you plot the PDF to paper? They usually look different on a monitor than they do on paper. Quote Link to comment Share on other sites More sharing options...
WPerciful Posted March 18, 2014 Author Share Posted March 18, 2014 The drawing was ploted from AutoCAD to the printer. Then it was plotted to “DWG To PDF.pc3”. Once the PDF was made it was printed to the same printer. The PDF print matches what was displayed on the screen, but it does not match the one in which it was sent right to the printer. The hatch in the clients logo isn't solid in the PDF print, and the line weights are much lighter. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted March 18, 2014 Share Posted March 18, 2014 I'm going to assume you did not change anything other than the plotter but check to make sure that all the settings are the same in the plot dialog box. Also, check the properties for the DWG to PDF plotter. I would look in the graphics section and make sure that lines merge is on. Quote Link to comment Share on other sites More sharing options...
hamzasirri Posted June 22, 2014 Share Posted June 22, 2014 Remove the tick mark from scale line weights during your plot to PDF this happen to me before http://s18.postimg.org/fm6ltu4m1/SNAG_Program_0000.jpg Quote Link to comment Share on other sites More sharing options...
