Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Full Member
    AutoCAD 2012
    Feb 2014
    40
    Default How do I snap from center of a circle?
    Hello there I'm just wondering how I would snap to the center of a circle like the picture below? If I wanted to snap 500 units from the center of the circle and add a new object how would I do that?
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,118
    Take a look at modifiers, in particular "from"
    Full Member
    AutoCAD 2012
    Feb 2014
    40
    Quote Originally Posted by steven-g View Post
    What modifiers? How do I find them?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,737
    Command: L
    LINE
    Specify first point: from
    Base point: pick the center of your circle (make sure OSnaps are on)
    Now place your cursor on the side of the circle where you want the line to go.
    <Offset>: 50 (type in your distance); this will be the starting point of your line. Continue with the command.
    "From" and "MTP" (Mid-to-Point) are said to be command modifiers as they can only be used AFTER a command has been started. They are not commands in and of themselves.
  5. #5
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Object Snap Tracking can do it, also.
    Drafting is a breeze.
  6. #6
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,118
    point filters are another really good way of locating things, in relation to other objects. I remember struggling to understand them, but I use it all the time now, the Autocad help files do give good examples.
  7. #7
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    First turn OSNAP on, using the button at the bottom of the screen (I have the names displaying instead of the icons, if you are using icons it is the 6th one from the right), right click, go into settings and make sure Center is one of the choices.
    Turn on OTRACK (8th icon from the right).
    Start a command, now move the cursor over the edge of the circle, then move to the center of the circle, you will see an indication that you have acquired a point (at this point you have not picked a point). Now move the cursor in the direction desired making sure the rubber band line is showing for a direction of zero degrees, or whatever is desired, type in 500 and hit enter.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  8. #8
    Senior Member SAFeSTeR's Avatar
    SAFeSTeR's Computer Details
    W7 64-bit
    Intel Xeon @ 3.20Ghz
    12 GB
    Utilities
    SAFeSTeR's Discipline Details
    CAD Technician
    Utilities
    Water main replacement schemes.
    AutoCAD 2016
    Jul 2012
    Bristol, England
    258
    [/I]"From" and "MTP" (Mid-to-Point) are said to be command modifiers as they can only be used AFTER a command has been started. They are not commands in and of themselves.
    Do you mean M2P (Mid Between 2 Points)? I looked for mid to point in my CUI but found nothing.
    EDIT: Just tried MTP and found it does exactly the same as M2P. I guess it could mean 'mid between two points' rather than 'mid to point', but that would be a minor detail
  9. #9
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    Looks to me like object tracking is the easiest method, but there is certainly nothing wrong with creating construction geometry. I create more construction geometry now than I did back on the drawing board. (and don't erase it - it might come in handy in the future, simply put it on a hidden layer)
  10. #10
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Are 'modifiers' another name for osnaps?
  1. Center object snap.
    By prime333 in forum AutoCAD Beginners' Area
    Last Post: 3rd Mar 2014, 09:37 am
  2. 3D Center circle
    By kalimero in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jan 2011, 05:06 pm
  3. circle center line(Like Plus symbol and after circle 4 sides 5mm extra length)
    By johnpieter in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Dec 2010, 02:23 pm
  4. Circle-Isometric Snap
    By Shibuboss in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Aug 2009, 01:41 am
  5. How to snap arc to circle tangent?
    By mrsnature in forum AutoCAD Beginners' Area
    Last Post: 19th Sep 2006, 04:21 pm
