Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 54
  1. #11
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    To get a circle of radius 9 exactly, the offset should be 5.39227909
  2. #12
    Full Member issammm's Avatar
    issammm's Computer Details
    Windows 7 64bit
    DELL inspiron 1525
    i7-3517U @ 1.90GHz
    8 GB
    AMD Radeon 8700 2GB
    750GB
    Architectural
    issammm's Discipline Details
    Programmer
    Architectural
    AutoCAD draftman
    AutoCAD 2013
    Jul 2013
    Jordan
    52
    yes my autocad just 4 precision. can you give me your way in detail you just make vertical line but how you get the second tangent point ?
  3. #13
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    Issammm, your original question was not stated correctly. If you had stated that the radius, Rx, was to be 9 and the offset was the variable, you would have been given a solution that was quite easy. Draw the circle with the TTR option, selecting the two circles and specifying 9 for the radius.
    Drafting is a breeze.
  4. #14
    Windows 7 64bit
    DELL inspiron 1525
    i7-3517U @ 1.90GHz
    8 GB
    AMD Radeon 8700 2GB
    750GB
    Architectural
    Programmer
    Architectural
    AutoCAD draftman
    AutoCAD 2013
    Jul 2013
    Jordan
    52
    Quote Originally Posted by RobDraw View Post
    my question is OK, eldon give me correct answers in too accurate.
    jst eldon give us more precision than needed.
    the Rx = 9 for case 5.3923
    regards to all
  5. #15
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Issammm, I gave you above the radius, calculated as per your sketch, with 8 decimals and a solution to use it; isn't that enough for your sketch?
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  6. #16
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    How can it be when you are changing the value, 5.4152, to a variable and assigning a value where you had a variable, Rx?
  7. #17
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Quote Originally Posted by issammm View Post
    both solution incorrect, if you correct please give me Rx here.
    Seems that you were asked for the radius in the first place!
    Regards,
    Mircea
  8. #18
    Windows 7 64bit
    DELL inspiron 1525
    i7-3517U @ 1.90GHz
    8 GB
    AMD Radeon 8700 2GB
    750GB
    Architectural
    Programmer
    Architectural
    AutoCAD draftman
    AutoCAD 2013
    Jul 2013
    Jordan
    52
    Quote Originally Posted by MSasu View Post
    MSasu you are completely correct.(I hope you explain how you got your answer)
    Rob i hope you give me correct answer next time all my replay was clear.
    if you want more challenge draw this and find all arcs length.
  9. #19
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    It seems that there are not enough figured dimensions. For example, where is G? Is it at the end of a semicircle?
    One could guess, but that might not be sufficiently accurate for you
  10. #20
    Windows 7 64bit
    DELL inspiron 1525
    i7-3517U @ 1.90GHz
    8 GB
    AMD Radeon 8700 2GB
    750GB
    Architectural
    Programmer
    Architectural
    AutoCAD draftman
    AutoCAD 2013
    Jul 2013
    Jordan
    52
    Quote Originally Posted by eldon View Post
    points B till I are tangents points except A is a vertex, think well you will get it.
  1. Replies: 27
    Last Post: 12th Nov 2013, 02:57 pm
  2. Replies: 10
    Last Post: 10th Oct 2013, 05:30 pm
  3. How to draw a circle so that a line becomes a tangent to it
    By Surajit in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Feb 2013, 06:27 pm
  4. Draw a 3rd circle tangent to 2 circles
    By dniemeye in forum AutoCAD Beginners' Area
    Last Post: 30th Jun 2011, 02:02 pm
  5. Tangent circle
    By boofredlay in forum AutoCAD General
    Last Post: 26th Sep 2005, 07:42 pm
