Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Junior Member
    AutoCAD LT 2012
    Mar 2014
    19
    Default %%O%%C%%O Character
    Hello all.
    Kindly find attached drawing which shows simple reinforcement schedule. I have a problem with Texts which are shown in yellow color.When I click on one of them - for example 1∅16 L=1175 , at the properties area, I see text Contents 1%%O%%C%%O16. When I try to find 1∅16 I can't find anything.
    I tried searching %%C and Autocad found all of yellow texts. But when I select Replace All with ∅16 value, it becomes 1%%O%%∅%%O16. After that when i make search %%O%% or %%O or O%% ( I tried lots of combinations ) Autocad cant find anything so I cant change any value
    I have a lisp to use, and i have to find texts which include ∅ ( Char216) but i can't change contents of text.
    How can I change value of all contents ??
    Junior Member
    AutoCAD LT 2012
    Mar 2014
    19
    I think I asked a bit complicated question
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,162
    There is a list of %% combo's its not many easier is use mtext and you have a pull down of the special characters, also you can use TTF like windings for special characters.
    %%c diameter
    %%u underline
    %%d superscript degree
    Junior Member
    AutoCAD LT 2012
    Mar 2014
    19
    So you mean I cant use find command to find 1%%O%%C%%O16.So it means I cant highlight or edit all yellow texts in same time????
  5. #5
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    How did you even get the diameter symbol into the FIND box? Are you searching for %%O (oh) or %%0 (zero)?
    When using FIND, you have to search for the special characters, not the symbol, FIND %%c 16 for instance.
    When the user enters text, AutoCad does a text override of sorts when it sees the %%c and displays, and plots the symbol instead. The property content is still %%c, not the Dia. symbol. FIND does not see the symbol. Inserting a symbol from the text edit drop down symbol list also results in the same property content as typing %%c.
    FIND %%c 16
    Replace with %%c 17 Will give you the diameter symbol followed by 17 for a result.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  6. #6
    Junior Member
    AutoCAD LT 2012
    Mar 2014
    19
    Actually I've uploaded the drawing at my first post to make my question more understandable. I know %%c is dia symbol and %%o means upperline etc. And I know Autocad cant find if i try to find Dia instead of %%c .
    When I try to find %%c, everything is ok as I have mentioned about at my first post. I can find all texts which include %%c and I can replace with any value what i want. For example I found %%c and I selected Replace All with @ value and all of %%c values became @
    But I couldnt find %%o or after replacing %%c with @ All text Content values became %%O@%%O and I couldnt find again.
    Actually the question is simple. I want to find and delete all %% values from inside of yellow texts. I can select texts one by one and make revisions but I want to modify all yellow texts in same time. I dont want to see any %% value in Content area
  7. #7
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    Well, your first post did not say anything about how advanced you are, so I tried to communicate at a level workable for everyone.
    I have tested many scenario's and have yet to have any trouble locating any of those special character strings.
    FIND is case sensitive. Now all the upper case "C" and "O" are lower case, and then you throw in yet another symbol.
    in order to solve a problem it has to not be continually obfuscated with either previously left out information, or new conditions.
    I'm sorry, but I don't have anything further to add.
  8. #8
    Junior Member
    AutoCAD LT 2012
    Mar 2014
    19
    FIND is not case sensitive for finding %%c
    you can find same result if you try %%c or %%C. Anyhow, there s no solution about that, so I should wait or find out
  9. #9
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,743
    I stand corrected, FIND is not case sensitive IF you have the match case box unchecked, which I usually have checked and did, which helps me even less to understand why these character strings are not being found.
  10. #10
    Junior Member
    AutoCAD LT 2012
    Mar 2014
    19
    Really I dont understand how autocad cant find %%o or any combination of it,while it can find %%c
    Because of that small issue i couldnt run my lisp.Because i cant define string value to find.Same like Autocad,lisp cant find %%o too,so it cant work If I find solution i will share.Thank you for your efforts
  1. new line in character
    By john_ in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Feb 2015, 01:02 am
  2. null character
    By potencjalek in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jan 2014, 12:35 am
  3. Character modelling
    By evilsorcerer1 in forum Rigging & Animation
    Last Post: 16th Aug 2013, 04:24 pm
  4. Spaces between character???
    By myself in forum AutoCAD General
    Last Post: 7th Jan 2009, 05:13 pm
  5. Character Map Symbols
    By Darrell Miller in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th May 2008, 03:27 am
Tags for this Thread
