Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,723
    I converted your drawing to 2007 format so I could open it, ran several tests and cannot get FIND to locate any of those %% character strings. I am completely at a loss on how to figure this one out.
    I even ran Audit and -purge, got rid of a bunch of regapps and all extra left-overs. Still Nothing.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  2. #12
    Junior Member
    AutoCAD LT 2012
    Mar 2014
    19
    There is 2 solution about that
    1. Install alternative cad program ( thats autocad forum so because of that i dont want to give a name program but foxies know which program i m talking about from china ) and easily you can use find and replace all
    2.Thanks to member ymg3 ,you can load lisp to change values what you want.
    Lisp command is ymg3 as u know.
    (defun c:ymg3 ()
    (setq ss1 (ssget "ALL" (list (cons 0 "TEXT"))))
    (if ss1
    (repeat (setq n (sslength ss1))
    (setq en (ssname ss1 (setq n (1- n)))
    enl (entget en)
    otxt (cdr (assoc 1 enl))
    ntxt (vl-string-subst (chr 216) "%%O%%C%%O" otxt)
    enl (subst (cons 1 ntxt) (assoc 1 enl) enl)
    (entmod enl)
    The problem is solved i think
  3. #13
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,723
    OK, then. If you want to go that route..........
  4. #14
    Forum Newbie
    AutoCAD 2014
    Apr 2015
    2
    Sorry, I know this is an old thread - but similar question.
    Number of years ago, people used a non std font 'ISO3098B'. It had special characters such %%130 to represent the character I. That is, people wanted a simple single stroke font such as ISOCP - but for certain drawings, the character I had to drawn with the top and tail (serifs I think they're called)
    And as we all know, when the drawing is passed onto someone else who does not have this font - the special character is displayed as a ?
    These days Engineers don't care if the I is not displayed with the serifs. How can I use the Find utility to replace %%130.
    Tried using `? and `%`%130
    The old 'chgtext' lisp routine works, but only on straight text and not Attributes, etc
    Thanks
  5. #15
    Forum Newbie
    AutoCAD 2014
    Apr 2015
    2
    I received an answer from another source, so thought I'd post it here in case anyone is interested.
    Double click the text entity that contains the special character, so it opens the text editor. Highlight the character that is displayed as a question mark, and copy it to the clip board.
    Then run the Find command, click in the 'Find What' field, then Paste. What you pasted won't be visible. Then continue with the find/replace as normal.
    Thanks
  1. new line in character
    By john_ in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Feb 2015, 01:02 am
  2. null character
    By potencjalek in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jan 2014, 12:35 am
  3. Character modelling
    By evilsorcerer1 in forum Rigging & Animation
    Last Post: 16th Aug 2013, 04:24 pm
  4. Spaces between character???
    By myself in forum AutoCAD General
    Last Post: 7th Jan 2009, 05:13 pm
  5. Character Map Symbols
    By Darrell Miller in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th May 2008, 03:27 am
Tags for this Thread
