after loding lisp : "error no function definition , ACET-STR-FORMAT"
Salama
Hi,
currently i found on the web , this lisp to draw Road profile or any other profiles by the lisp that contains two commands :
1- " NGL " : To draw natural ground elevation in terms of station and elevation from an excel sheet with a Datum .
2- "PGL" : tO DRAW DESIGN ELEVATION from excel sheet too , with same datum.
the lisp states an error message "error no function definition , (ACET-STR-FORMAT ) after loading " NGL" and entering datum , BUT it work with " PGL" without any error ... ??!!
i use AutoCAD2012 ? , what do you think that the problem is ?error message for  this lisp in NGL command.png
lisp and excel are attached .
https://www.mediafire.com/?dqbumocn3gm3132
PROFILE #NGL# - #PGL#.lsp
Edited by Salama
  • 2 weeks later...
i tried this , and loaded express tools , but still same message appears .
(setq datscaled (list (car datreal)(* verscale (cadr datreal)) ))
(setq opt nil)
(while (and(/= opt "Yes")(/= opt "No"))
(SETQ dopt "Yes")
(initget "Yes No Options")
(setq option (getkword (acet-str-format "\nAttach Start-up Template [Yes/No/Options] : " Dopt))
option (if option option Dopt) )
(IF (= option "Options")
(pro)
(setq opt option)
is there any approach to avoid that error ?? , the part of LISP that includes the appeared error text: " acet-str-format " .
