121madhu Posted March 22, 2014 Share Posted March 22, 2014 Hi anyone please help me I received .dwgs from consultant model space is all .dwgs same but layouts different so I insert all .dwgs layouts to single .dwg and multi layouts I am using design center –open file folder location –then select drawing –layout –drag my current dwg. This is okay but taking so much time any other way to do this please help me Thank you Quote Link to comment Share on other sites More sharing options...
Tharwat Posted March 22, 2014 Share Posted March 22, 2014 Not clear enough to me at least , and may need a sample drawing or more details . Quote Link to comment Share on other sites More sharing options...
Dana W Posted March 22, 2014 Share Posted March 22, 2014 Do you realize you posted in the lisp forum? Is that what you are looking for, a lisp to run a multi--sheet plot from many drawings? If not, you can simply use the publish command. You can browse and add other drawings to one sheet list. Quote Link to comment Share on other sites More sharing options...
hmsilva Posted March 22, 2014 Share Posted March 22, 2014 ... I am using design center –open file folder location –then select drawing –layout –drag my current dwg. This is okay but taking so much time any other way to do this please help me ... If I have understood correctly, maybe Lee Mac's "Steal from Drawing" do that you want to... HTH Henrique Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 22, 2014 Share Posted March 22, 2014 If you want to plot multiple title blocks in Modelspace then search here under lisp for Model & Plot it can be done in one go if you can not find post again and I will repost it. Quote Link to comment Share on other sites More sharing options...
121madhu Posted March 24, 2014 Author Share Posted March 24, 2014 sorry for my poor English my problem is not a polting check this two jpeg files to under stand my q. i am received dwgs from consultant this all dwgs model are same but layouts change so i want make all dwgs to one dwg (i am using designcenter ctrl+2 then open folder location-dwg-layout i drag and drop layout to my single dwg ) this is taking more time any another way to dwg layout insert our dwg thank you Quote Link to comment Share on other sites More sharing options...
Dana W Posted March 24, 2014 Share Posted March 24, 2014 Asking the same question over again without explaining why the current suggested methods or solutions do not work for you, is not what I expected to see. One more time; Are you looking for a lisp program, or will the publish or batch plot options work? Have you looked into creating a sheet set? Quote Link to comment Share on other sites More sharing options...
manohar Posted March 24, 2014 Share Posted March 24, 2014 I am not a lisp programmer. I think i got what madhu wants. His whole drawing is divided into multiple sheets. Each sheet is saved as individual drawing . He is using Design centre to combine all the Sheets in to single drawing. Is there any other easy way to do this since his method is taking more time. i hope i conveyed better than him . Quote Link to comment Share on other sites More sharing options...
hmsilva Posted March 24, 2014 Share Posted March 24, 2014 121madhu, try the attached code, if you don't have any layout with the same name than those you gonna copy, will copy to the current dwg all layouts from selected dwg's. This routine uses Lee Mac's "Get Files Dialog" and "Steal from Drawing" download those routines and save the routines in a Support File Search Path directory. (defun c:test (/ a b files file) (if (and (setq a (findfile "GetFilesV1-3.lsp")) (load a) (setq b (findfile "StealV1-8.lsp")) (load b) (setq files (LM:getfiles "Select Files" nil "dwg")) ) (progn (foreach file files (Steal file (list (list "Layouts" (list "*")))) ) (command "_.regen") ) ) (princ) ) HTH Henrique Quote Link to comment Share on other sites More sharing options...
Dana W Posted March 24, 2014 Share Posted March 24, 2014 Asking the same question over again without explaining why the current suggested methods or solutions do not work for you, is not what I expected to see. One more time; Are you looking for a lisp program, or will the publish or batch plot options work? Have you looked into creating a sheet set? Since there are no responses, good luck with your future endeavors. Quote Link to comment Share on other sites More sharing options...
ROBP Posted March 25, 2014 Share Posted March 25, 2014 Do you realize you posted in the lisp forum? Is that what you are looking for, a lisp to run a multi--sheet plot from many drawings? If not, you can simply use the publish command. You can browse and add other drawings to one sheet list. So what the user posted it in the wrong section nobody is perfect you should know that Quote Link to comment Share on other sites More sharing options...
121madhu Posted March 25, 2014 Author Share Posted March 25, 2014 I am not a lisp programmer. I think i got what madhu wants. His whole drawing is divided into multiple sheets. Each sheet is saved as individual drawing . He is using Design centre to combine all the Sheets in to single drawing. Is there any other easy way to do this since his method is taking more time. i hope i conveyed better than him . yes this is correct any other way using lisp to do this Quote Link to comment Share on other sites More sharing options...
121madhu Posted March 25, 2014 Author Share Posted March 25, 2014 Lee Mac's "Steal from Drawing" is working(steel a layout) but this also doing one by one not taking entire folder this also same design center(ctrl+2) i need easy way using lisp to save my time because i have lots of folder to do this thank you Quote Link to comment Share on other sites More sharing options...
Dana W Posted March 25, 2014 Share Posted March 25, 2014 So what the user posted it in the wrong section nobody is perfect you should know thatI asked the OP a legitimate question. What I didn't ask for was for somebody to read an attitude into my post which I didn't have until this very minute. As you will see from posts #12 and #13, the OP did not post in the wrong section, even though nobody knew that until now, and my question was answered, FINALLY, even though not addressed directly. Quote Link to comment Share on other sites More sharing options...
hmsilva Posted March 25, 2014 Share Posted March 25, 2014 Lee Mac's "Steal from Drawing" is working(steel a layout) but this also doing one by one not taking entire folder this also same design center(ctrl+2) i need easy way using lisp to save my time because i have lots of folder to do this thank you Did you try the code in message #9? Henrique Quote Link to comment Share on other sites More sharing options...
121madhu Posted March 26, 2014 Author Share Posted March 26, 2014 Did you try the code in message #9? Henrique yes but not working Quote Link to comment Share on other sites More sharing options...
hmsilva Posted March 26, 2014 Share Posted March 26, 2014 yes but not working Why? Any error messages? Henrique Quote Link to comment Share on other sites More sharing options...
manohar Posted March 26, 2014 Share Posted March 26, 2014 Why?Any error messages? Henrique Code in post #9 & LM's Lisp is working for me. Tested in ACAD2010. Thanks Henrique & Lee. It might help me in future. Lee Mac's "Steal from Drawing" is working(steel a layout) but this also doing one by one not taking entire folder this also same design center(ctrl+2) i need easy way using lisp to save my time because i have lots of folder to do this thank you Dear Madhu. Load Henrique's lisp last after loading LM's two lisp. I think this may due to both has test command with different function. or change the command name in Henrique's lisp. Quote Link to comment Share on other sites More sharing options...
121madhu Posted March 31, 2014 Author Share Posted March 31, 2014 121madhu,try the attached code, if you don't have any layout with the same name than those you gonna copy, will copy to the current dwg all layouts from selected dwg's. This routine uses Lee Mac's "Get Files Dialog" and "Steal from Drawing" download those routines and save the routines in a Support File Search Path directory. (defun c:test (/ a b files file) (if (and (setq a (findfile "GetFilesV1-3.lsp")) (load a) (setq b (findfile "StealV1-8.lsp")) (load b) (setq files (LM:getfiles "Select Files" nil "dwg")) ) (progn (foreach file files (Steal file (list (list "Layouts" (list "*")))) ) (command "_.regen") ) ) (princ) ) HTH Henrique yes got it thank you hmsilva and LeeMac first i confused Support File Search Path directory now its good thank you so much Quote Link to comment Share on other sites More sharing options...
hmsilva Posted March 31, 2014 Share Posted March 31, 2014 You're welcome, Madhu Glad I could help Henrique Quote Link to comment Share on other sites More sharing options...
