bjenk8100 Posted March 22, 2014 Share Posted March 22, 2014 Hello, I made a gear and a chain link. I wanna have the chain links go around the gear. I found a method that works but it just takes so long inserting individual chain link components into an assembly and mating each individual ones together. Can someone take a look at my assembly and see if they can think of a quicker way. I am thinking some sort of circular pattern. I am working on that now but it is not easy. Thanks Assem1 - Gear and Chain Links.SLDASM Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 22, 2014 Share Posted March 22, 2014 An assembly must have parts. Quote Link to comment Share on other sites More sharing options...
bjenk8100 Posted March 25, 2014 Author Share Posted March 25, 2014 Huh, I wonder why the file saved as a solidworks 2013 application (file type) instead of a prt. (file type). I don't ever remember that happening before. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 25, 2014 Share Posted March 25, 2014 I have no idea what you are talking about? application file? What is that? Where is that? You attached an assembly file *.sldasm. In the real world - an assembly must have parts to be of any value. A car assembly with no parts isn't much of a car? A SolidWorks assembly file is nothing more than a list of hyperlinks to the parts that go into the assembly and instructions on how to put them together - a list of assembly constraints. Put all of the files in one folder. What is the size of the folder? Add up all the part file (*.sldprt) files - what is the total size? Compare this total to the size of the assembly file. What is the difference? Quote Link to comment Share on other sites More sharing options...
bjenk8100 Posted March 25, 2014 Author Share Posted March 25, 2014 I started a new part as a gear. I started a new part as a gear. They are not normal part file extensions in folder. The assembly is a normal file extension. When I get home I'll delete assembly file and I gaurantee they will turn back into part files. Quote Link to comment Share on other sites More sharing options...
