bam8 Posted March 23, 2014 Share Posted March 23, 2014 I am pretty rusty with my AutoCAD skills, but when I was decent, I used to know a command that would allow you to move an object the distance in one direction by using the move command and selecting a second point on another object. So if I used the move command, selected the object I wanted to move and base point, used another command (the one I can't think of), then clicked on a second point on another object the object I wanted to move would only move in the X direction, let's say, instead of the XY and Z I'm having a hard time explaining this I can try again if this doesn't make any sense to anyone. Quote Link to comment Share on other sites More sharing options...
bam8 Posted March 23, 2014 Author Share Posted March 23, 2014 Resolved Well I Still have not figure out the command I was thinking of but using point filters does the job. So if anyone else has this problem here would be the blow by blow move select object specify base point .x (type either .x .y or .z depending which direction you need to move) select second point on another object click one more time Quote Link to comment Share on other sites More sharing options...
Dadgad Posted March 23, 2014 Share Posted March 23, 2014 Welcome to CADTutor. You may want to try using the 3DMOVE command, as it will facilitate movement pinned to an axis. In order to better visualize and more easily define selections, I like using an isometric perspective when doing this. Quote Link to comment Share on other sites More sharing options...
bam8 Posted March 23, 2014 Author Share Posted March 23, 2014 thanks very much, I believe that was the one! Quote Link to comment Share on other sites More sharing options...
rkent Posted March 23, 2014 Share Posted March 23, 2014 You can also do this with Move, enter, pick, enter, (do not pick a displacement point), 0,0,10, enter, enter. This will move what ever you picked in the Z coordinate 10 units. For X you would use 10,0,0. For Y you would use 0,10,0. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 24, 2014 Share Posted March 24, 2014 If only x & y press F8, Move, pick object, drag X or Y, enter distance, all done. For perp to angle line UCS Ob pick line repeat above UCS W. Quote Link to comment Share on other sites More sharing options...
