Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Senior Member shailujp's Avatar
    shailujp's Computer Details
    Windows 7 64 bit
    Dell Precision T1650
    16 GB
    AMD FirePro V5900 (ATI FireGL)
    Dell
    Mechanical
    shailujp's Discipline Details
    Designer
    Mechanical
    Machine design, Mould Design and general drafting work
    AutoCAD 2015
    Jun 2013
    Mumbai - India
    167
    Default Duplicate numeric text finder
    Hi all,
    I'm looking for a way to check my BOM lines (mostly copied from multiple drawings) for duplicate part numbers (all number, no alphabets but might have - or _) in an attribute block with a tag named DESCRIPTION & SAPNUMBERS.
    Example
    If the description says 12345 in one line and if the same is found on the another line in the description column then thats duplicate. Similarly on the SAPNUMBER column as well. If one of these return true then I will evaluate both the lines manually.
    Dont want to delete anything here. Just want to make sure I dont have same line repeated twice on the BOM. If found, I will just adjust the qty and delete one. Thats manual work that I do.
    Does anyone have any utility that I can use?
    Thank you.
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    Is that within one single block?
    Windows 7 64 bit
    16 GB
    Dell
    Mechanical
    Designer
    Mechanical
    AutoCAD 2015
    Jun 2013
    Mumbai - India
    167
    Nop. each BOM line is one attribute block and same is copied multiple times to make complete BOM.
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    So how do you propose to show the duplicates then?
  5. #5
    Windows 7 64 bit
    16 GB
    Dell
    Mechanical
    Designer
    Mechanical
    AutoCAD 2015
    Jun 2013
    Mumbai - India
    167
    May be highlight two entities. In most cases there are only couple of duplicates. If all duplicated are highlighted, it wont be difficult to work thru the selection. Do you have any better idea?
  6. #6
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    We want to see what you have to start with. drawing file that is.
  7. #7
    Windows 7 64 bit
    16 GB
    Dell
    Mechanical
    Designer
    Mechanical
    AutoCAD 2015
    Jun 2013
    Mumbai - India
    167
    I have attached a sample file. I'm sorry I not very clear on your question though. Is this what you were looking for?
  8. #8
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    No time to wait for your sample
    Code:
    Code removed [refer to post # 14]
  9. #9
    Windows 7 64 bit
    16 GB
    Dell
    Mechanical
    Designer
    Mechanical
    AutoCAD 2015
    Jun 2013
    Mumbai - India
    167
    pBe,
    Works wonderfully well. Your lisp draws lines between two duplicate is a much better option. Thank you very much
    Edit: I got the tag name SAPNUMBERS incorrect on the sample file. I have fixed it on my pc.
  10. #10
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    The updated code draws a rectangle. you can do the rest like creating a layer for the rectangles and what not.
  1. numeric text editing (add or subtracting)
    By VisDak in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Apr 2017, 06:23 pm
  2. Add or subtract from a station label with alpha-numeric text
    By JPayne in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Sep 2013, 09:21 pm
  3. Removing all numeric prefixing part of text objects
    By Organic in forum AutoCAD General
    Last Post: 12th Jul 2011, 12:15 pm
  4. bulk editing numeric text
    By tomals in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Jun 2009, 03:13 pm
  5. change precison of numeric text
    By motee-z in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Apr 2008, 08:00 pm
Tags for this Thread
