Results 1 to 7 of 7
    Senior Member shailujp's Avatar
    shailujp's Computer Details
    Windows 7 64 bit
    Dell Precision T1650
    16 GB
    AMD FirePro V5900 (ATI FireGL)
    Dell
    Mechanical
    shailujp's Discipline Details
    Designer
    Mechanical
    Machine design, Mould Design and general drafting work
    AutoCAD 2015
    Jun 2013
    Mumbai - India
    167
    Default CONVERTPSTYLES using a script issue
    Hello,
    I have some drawings that requires CONVERTPSTYLES run to be able to use the plot style .ctb files. Otherwise it shows missing.
    So, I have created a script per below (btw my first script ever ).
    Code:
    CONVERTPSTYLES
    QSAVE
    QUIT
    This script works well if all the files in folder has the issue of missing plot style. If any one file is not having this issue, then the script stops. I noticed that the CONVERTPSTYLES is having two different responses and if the file does not have any issue, then it pops-up different window causing my script to stop.
    The first image is the normal pop-up and once okayed. command closes for the problematic files (works perfectly).
    Second image is the additional pop-up looking for some files when the file is having no issues.
    Any suggestions
    Full Member
    AutoCAD 2012
    Sep 2011
    Sweden
    40
    Hi shailujp,
    First I will refer to the AutoCAD help:
    A drawing can use either named or color-dependent plot styles, but not both.
    CONVERTPSTYLES converts a currently open drawing from color-dependent plot styles to named plot styles, or from named plot styles to color-dependent plot styles, depending on which plot style method the drawing is currently using.
    When you convert a drawing, CONVERTPSTYLES sets the PSTYLEMODE system variable to the appropriate setting (0 = named, 1= color-dependent).
    For example, a drawing using color-dependent plot styles assigns plot properties to objects and layers by color. In other words, all objects with the same color have the same plot properties. CONVERTPSTYLES converts the drawing to use named plot styles that can be applied to objects or layers independent of color assignment. In other words, all objects with the same color can have different plot properties.
    A script file is not built on conditions. You can´t write a script that checks if a line is blue and if it is then turn it red.
    A script just turns it red, no matter what.
    But if you write a lispfile you can set conditions.
    The following code checks if the system variable PSTYLEMODE is 0 (Named plot style) and if it is, then it runs the command CONVERTPSTYLES otherwise it don´t.
    Code:
    (if (= (getvar "PSTYLEMODE") 0)
     (command "convertpstyles")
    (command "_.qsave")
    If you want to load a lispfile from a scriptfile then you write like this in you´r scriptfile.
    Code:
    (load "c:\\temp\\lispfile.lsp")
    Maybe it´s possible to eliminate the root of the problem rather than fixing it like this but I´m not that good with ctb and stb files.
    Windows 7 64 bit
    16 GB
    Dell
    Mechanical
    Designer
    Mechanical
    AutoCAD 2015
    Jun 2013
    Mumbai - India
    167
    Thank you ripuz.
    Your suggestion worked for me. Now when I run this script, it goes smooth and no stopping whatsoever.
    One more thing I learned about lisp today. I was under impression that LISP file must contain DEFUN but I was wrong.
    Got one question on the batch file though. Currently I'm using below code for the batch file. I copy all my files-to-convert into this folder and run the utility. Is it possible to allow for selection of the folder so that I dont have copy/paste drawings to this folder? Or should I change the folder name inside batch each time? Just want to know how others do this?
    Also, how to add multiple folders so that I can run this on say five different folder.
    And if possible, can someone describe the functions listed under the batch code.
    Code:
    FOR %%V IN (C:\Myfolder\*.dwg) DO start "T" /w "C:\Program Files\AutoCAD 2008\acad.exe" %%V /b "FIXPSTYLE.scr"
    Windows 7 64 bit
    16 GB
    Dell
    Mechanical
    Designer
    Mechanical
    AutoCAD 2015
    Jun 2013
    Mumbai - India
    167
    I have did some basic reading on some websites but couldnt find what START, "T" and /W stands for. Any clue?
  5. #5
    Forum Newbie
    Map 3D 2014
    Sep 2016
    2
    Hi to All.
    excuse me but i don't see the Code,.
    Do you can send it to me? ...or directly the lisp file.
    Thanks a lot
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Why not
    Code:
     (setvar "Pstylesmode" 1)
    You could use Lee-mac scriptwriter and run it all from inside Autocad, also use in a lisp FINDFILE and write a script so directory is not hard coded.
    Me I would just use
    CMD
    cd\myfolder
    Dir *.dwg > dirlst /b
    open dirlist in word use Replace and script is done.
    open dwg1 z e (if (= (getvar "PSTYLEMODE") 0) (setvar "Pstylesmode" 1)) qsave
    open dwg2 z e (if (= (getvar "PSTYLEMODE") 0) (setvar "Pstylesmode" 1)) qsave
    open dwg3 z e (if (= (getvar "PSTYLEMODE") 0) (setvar "Pstylesmode" 1)) qsave
  7. #7
    Forum Newbie
    Map 3D 2014
    Sep 2016
    2
    Idea Great
    THANKS A LOT BIGAL!
    Quote Originally Posted by BIGAL View Post
    Why not
    Code:
    Me I would just use
    CMD
    cd\myfolder
  1. script issue
    By cursedeye in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 3rd Aug 2012, 04:10 am
  2. Model scale / VP scale issue / Co-ordinates issue
    By Richard Radford in forum AutoCAD Beginners' Area
    Last Post: 26th Aug 2010, 11:16 am
  3. Script opening script
    By zera in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Jan 2010, 08:01 pm
  4. Batch Convertpstyles
    By Jhun Gonzalo in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jul 2009, 11:28 am
  5. Sub script and Super script Text
    By edwin in forum AutoCAD Beginners' Area
    Last Post: 1st Aug 2007, 08:07 pm
Tags for this Thread
