Documenting Drawing Changes
psuengineer84
I have been interested in putting together a LISP routine that opens up a notepad file with user notes regarding recent editing or other "FYI" information.
Is this reasonably plausible to do?
Or is there a better way to tackle ACAD documentation?
Where I work any time a drawing is revised a new AutoCAD file is made, XXX-XXX-XXX-Rev-A B C D........
Notes are placed in the title block revision area to describe the changes, as well as "clouding" the changes.
The old Rev gets put in a folder, within the project, called Void.
I am really talking about changes for internal use only, not part of the contract documents revisions and submissions. Traditionally, I make notes on a "Rob's Notes" layer that doesn't print. It works generally OK, but I was trying to improve it.
The notes may not be just changes, but notes regarding things that still need to be changed, designed, etc.
An engineer in our office uses notes in the drawing information box, but to see them you have to remember to go there to check it.
