Lisp Routine to count blocks with added attributes
ahank
I've tried several lisp routines to help count blocks that are color coded and also have a given attribute; but all the routines require me to select each block.
Is there a lisp routine that will count all blocks/ attributes within model space (only) and export to a table (or even better an Excel sheet)?
I want to include in the lisp routine what blocks to look for...
I'm a novice looking for a lot of help and would be greatly appreciated!!!
You hinted you looked at various lisps but using a filter will do what you want when selecting blocks looking at this snippet of code it has its filter set to a block of a certain name and must be in Modelspace. Once you have the selection set you can delve deeper and check the attribute value and count up.
(defun getblk (bname / ss1)
(setq ss1 (ssget "x"  (list (cons 0 "INSERT") (cons 2 bname)(cons 410 "Modelspace"))))
(princ (sslength ss1)) ; total number of blocks with that name found
(do something here total up attributes)
;This will get all blocks called Fred
(getblk "Fred")
; multiple runs
(getblk "Fred")
(getblk "Part56")
(getblk "Obj32")
