zonafpdesign Posted April 1, 2014 Share Posted April 1, 2014 If I have an invalid file message (I'm using autocad 2010) does that mean the file that I'm trying to open is 2014 or newer? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 2, 2014 Share Posted April 2, 2014 Autocad 2010 should be able to open 2011 and 2012 files, but the file format was changed with 2013. So if the drawing you have was done in 2013 or higher, you won't be able to open it. Or the file you have could be corrupt. Quote Link to comment Share on other sites More sharing options...
Dana W Posted April 2, 2014 Share Posted April 2, 2014 File format changes have been something like every three years, 2007, 2010, 2013... My 2009 won't open anything newer than the 2007 format. If your drawing is too new for your program it would say "Created with a newer version..." instead of "Invalid...". That message usually means there is something actually wrong with the file, as in corrupted. What is the source of the file? Quote Link to comment Share on other sites More sharing options...
zonafpdesign Posted April 2, 2014 Author Share Posted April 2, 2014 The file from a large Architectural company forwarded through the email of a small company that does not have CAD. Thank you for your response. That's the information that I was looking for. Mike Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 2, 2014 Share Posted April 2, 2014 You might check out DWG True Convert Quote Link to comment Share on other sites More sharing options...
