dsibbo Posted April 2, 2014 Share Posted April 2, 2014 Can anyone tell me how I can make a 600mmx600mm Square hatch pattern? Possibly using hatch pattern Net. I have one in work which is 1000x1000 but someone else set this up, so I would like to learn how to this. I'll then look to add it to a tool palette for future use. Quote Link to comment Share on other sites More sharing options...
rkent Posted April 2, 2014 Share Posted April 2, 2014 Start the hatch command, pick User Defined, set the value to 600, pick the double option, apply. Drag and drop to a tool palette, rename tool on palette. Quote Link to comment Share on other sites More sharing options...
dsibbo Posted April 2, 2014 Author Share Posted April 2, 2014 Thank You this worked perfect. Will my hatch, when dragged to the tool palette, work in all future drawings from now. Or will the hatch pattern have to be set up in them all first? Quote Link to comment Share on other sites More sharing options...
rkent Posted April 2, 2014 Share Posted April 2, 2014 It is in the tool palette so it will be available for use in any drawing, new or old. Quote Link to comment Share on other sites More sharing options...
dsibbo Posted April 2, 2014 Author Share Posted April 2, 2014 Great, so does this just update on my atc file on our server, which will then update on all machines who's autocad is directed to this file? Quote Link to comment Share on other sites More sharing options...
rkent Posted April 2, 2014 Share Posted April 2, 2014 Great, so does this just update on my atc file on our server, which will then update on all machines who's autocad is directed to this file? I am a one man show here so I don't know the answer. Quote Link to comment Share on other sites More sharing options...
rkent Posted April 2, 2014 Share Posted April 2, 2014 Start the hatch command, pick User Defined, set the value to 600, pick the double option, apply. Drag and drop to a tool palette, rename tool on palette. And set the layer in properties and it will always be placed on that layer. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted April 2, 2014 Share Posted April 2, 2014 Great, so does this just update on my atc file on our server, which will then update on all machines who's autocad is directed to this file?Yes it will as long as proper group policy and permissions are set correctly. Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted April 2, 2014 Share Posted April 2, 2014 If you're putting it on a tool palette, make sure that everyone who needs it is mapped to the same folders. This way it will be available to all of them. You have to set two folders in the options menu. The first is the Tool Palettes File Locations folder and the second (if you want them to have the ability to add to the palette, but they can also delete, so buyer beware) is the Authoring Palette File Locations. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 3, 2014 Share Posted April 3, 2014 A 2nd way for any sq hatch mesh is add this hatch pattern to acad.pat or a custom hatch pattern file that every one can get at on the server. just use this hatch pattern and set scale to desired size Original in acad.pat *NET, Horizontal / vertical grid 0, 0,0, 0,.125 90, 0,0, 0,.125 Add a new NET1 *NET1, Horizontal / vertical grid 0, 0,0, 0,1 90, 0,0, 0,1 Quote Link to comment Share on other sites More sharing options...
