3d hose
jdthompson9
I am trying to design a duct cleaner and I am having trouble modling a hose system to wrap around my vacuumme assembly. can anyone give me any pointers?
Entirely true, Remark! But if the discretization of that 3DPolyline in segments (by the way, is "defame" an appropriate term for this?) is small enough, the result may be a good enough approximation.
May get better results with a spline.
[ATTACH]47822[/ATTACH]
I want to take the hose out of the top hole and wrap around the base of the platform.
I'm not running Inventor. I'm not sure how a hose is created in that program.
First you will need to clarify what software you use! The question and your profile point to AutoCAD, but the file attached above say something else (Inventor).
I am using AutoCAD Inventor 2013.
There is no such thing as "Autocad Inventor". Autocad and Inventor are two separate programs. What you are using is "Autodesk" Inventor. Autodesk is the company, Inventor and Autocad are the programs.
I have moved your question to the Inventor forum. For best results, always post your questions in the proper area of the forum according to which program you are using.
I'll just leave this here ...
(Yes, I know it's an old version.)
That is a "Suite". It includes Autocad and Inventor. They are 2 separate programs. http://asean.autodesk.com/adsk/servlet/index?id=14678731&siteID=1157326
The "Autocad Inventor Suite 2010" contains Autocad Mechanical and Inventor.
It looks like the OP could benefit from the "Autocad Inventor Routed Systems Suite" which includes tube, pipe and flexible hose design.
Edited by Cad64
Added graphic
