pete1968 Posted April 5, 2014 Share Posted April 5, 2014 I am getting a error when sweeping this profile with a fillet. If i remove the fillet from the profile path it cuts fine. but i need the transition fillet. I dont understand why the fillet is a problem. Part1.ipt Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 5, 2014 Share Posted April 5, 2014 (edited) What is the purpose of Workplane1? Isn't it the same as the XZ plane? What is .5-.6875=? Why use a zero length dimension? Isn't that the same as a coincident constraint? Have you installed all Service Packs and Updates for your version of Inventor? (Hint: the answer is no.) It looks to me like you are doing extra work. I am running 2014 - post back if you want step-by step instructions for 2013. Edited April 5, 2014 by JD Mather Quote Link to comment Share on other sites More sharing options...
pete1968 Posted April 5, 2014 Author Share Posted April 5, 2014 Thanks I will download new service packs. I created the work plane to see if that was the problem. At first I just sketch plane. Tried a few different things but could not get it to work Quote Link to comment Share on other sites More sharing options...
pete1968 Posted April 5, 2014 Author Share Posted April 5, 2014 Could you show me what I'm doing wrong. Thank you for taking the time to help Quote Link to comment Share on other sites More sharing options...
pete1968 Posted April 7, 2014 Author Share Posted April 7, 2014 JD, I did this the same way with no problem. Don't understand why I'm getting the error on this of model. poly-a tube-1 25.ipt Quote Link to comment Share on other sites More sharing options...
Bishop Posted April 7, 2014 Share Posted April 7, 2014 Short answer is that either the radius is too tight or your circle is too big. If you're sweeping a circular profile along a path with curves in it - like this one - you need to make sure that the radius of the curves is greater than the radius of your circle or the profile will intersect itself (or even the path sometimes) as it comes around the corner.If you must have that radius as .500, then make your hole less than 1". If you must have the hole the size that it's at, then you need a corner radius greater than the radius of the hole. This, of course, applies only if you use sweep. If you were to create the holes in a different manner you might be able to keep your shapes as they are. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 7, 2014 Share Posted April 7, 2014 Sketch5 is unconstrained - missing dimensions and repeated dimensions? What happened to the hole location dimensions? Sketch7 is unconstrained and only one line required - what is the purpose of the other 3 lines? Workplane1 is a duplication of the YZ Plane (I am lazy, I try to avoid extra work). Sketch10 is unconstrained. Chamfer3 is not precisely the same geometry that would be created by a revolving tool (but close). Quote Link to comment Share on other sites More sharing options...
