Remove $ from layer name
mostafa badran
hi all,I need help, I need lisp which can remove $ from layer name ,block name ,style text ,etc. with explain the steps of syntax of lisp.
thanks for help.
mostafa
You can already accomplish this with the RENAME tool, utilizing wildcard matches to edit all names in these categories.
Thanks tzframpton fro respond,can you to clarify more,there's too much layers, blocks,the RENAME tool renamed as single category.
Start withthis one
(defun c:BF
  ;  BindFix15.lsp (AutoCAD 2000+)
  ;  Copyright 2003 | Michael Puckett | All Rights Reserved
     ;  local defuns
     __GetTableEntries
     __RenameTableEntry
     __RenameTableEntryViaObjname
     __RenameTableEntryViaActiveX
     __StripBindingArtifacts
     __GetUniqueTableEntryName
     ;  local vars
     doc
     newname
  ;  local defun
  (defun __GetTableEntries ( table / data result )
     (while (setq data (tblnext table (null data)))
        (setq result
           (cons (cdr (assoc 2 data)) result)
     result
  ;  local defun
  (defun __RenameTableEntry ( doc table oldname newname / data )
     ;  wrapper for __RenameTableEntryViaObjname
     ;  and __RenameTableEntryViaActiveX functions
     (setq table
        (cond
           ((eq (setq table (strcase table t)) "ltype") "linetype")
           (t table)
     (if (member table '("style" "dimstyle"))
        ;  autodesk made textstyles and dimstyles read-only to
        ;  the automation model w/regards to the symbol name, why?
        (__RenameTableEntryViaObjname table oldname newname)
        (__RenameTableEntryViaActiveX doc table oldname newname)
  ;  local defun
  (defun __RenameTableEntryViaObjname ( table oldname newname / data )
     ;  calling function responsible for
     ;  ensuring appropriate data passed
     (entmod
        (subst
           (cons 2 newname)
           (assoc 2 (setq data (entget (tblobjname table oldname))))
           data
  ;  local defun
  (defun __RenameTableEntryViaActiveX ( doc table oldname newname / data )
     (vla-put-name
        (vla-item
           (eval
              (list
                 (read (strcat "vla-get-" table "s"))
                 doc
           oldname
        newname
     ;  if you wanted this to be more robust
     ;  you could use the following ...
     ;  (vl-catch-all-apply
     ;     (function
     ;        (lambda ()
     ;           (vla-put-name ...)
     ;  I chose to pass valid data instead
  ;  local defun
  (defun __StripBindingArtifacts ( entry / i done )
     (cond
        (  (wcmatch entry "*`$#`$*")
           (setq i 0 ceiling (strlen entry))
           (while (and (not done) (< i ceiling))
              (if (wcmatch (substr entry (setq i (1+ i)) 3) "`$#`$*")
                 (setq
                    entry (substr entry (+ i 3))
                    done  t
     entry
  ;  local defun
  (defun __GetUniqueTableEntryName ( table entry )
     (cond
        (  (tblsearch table entry)
           (setq i 1)
           (while
              (tblsearch table
                 (strcat entry "_" (itoa (setq i (1+ i))))
           (strcat entry "_" (itoa i))
        (  t entry  )
  ;  "main"
  (cond
     (  (< 14 (atoi (getvar "acadver")))
        (vl-load-com)
        (setq doc (vla-get-activedocument (vlax-get-acad-object)))
        (foreach table '("block" "dimstyle" "layer" "ltype" "style")
           (foreach entry (reverse (__GetTableEntries table))
              (cond
                    (__RenameTableEntry
                       doc
                       table
                       entry
                       (setq newname
                          (__GetUniqueTableEntryName table
                             (__StripBindingArtifacts entry)
                    (princ
                       (strcat "\n"
                          (if (tblsearch table newname)
                             (strcat
                                "Renamed "
                                table " "
                                entry " => "
                                newname "."
                             (strcat
                                "Could not rename "
                                table " "
                                entry "."
     (  t (princ "\nSorry, penned for AutoCAD 2000+."))
Start withthis one
(defun c:BF
     ;  local defuns
     __GetTableEntries
     __RenameTableEntry
     ;  local vars
     doc
     newname
  ;  local defun
        (setq result
     result
  ;  local defun
     (setq table
        (cond
           (t table)
  ;  local defun
     (entmod
        (subst
           (cons 2 newname)
           data
  ;  local defun
     (vla-put-name
        (vla-item
           (eval
              (list
                 doc
           oldname
        newname
     ;     (function
     ;        (lambda ()
  ;  local defun
     (cond
                 (setq
                    done  t
     entry
  ;  local defun
     (cond
           (setq i 1)
           (while
              (tblsearch table
        (  t entry  )
  ;  "main"
  (cond
        (vl-load-com)
              (cond
                    (__RenameTableEntry
                       doc
                       table
                       entry
                       (setq newname
                    (princ
                       (strcat "\n"
                             (strcat
                                "Renamed "
                                table " "
                                entry " => "
                                newname "."
                             (strcat
                                "Could not rename "
                                table " "
                                entry "."
Thanks Mr asos2000 I will try this,thanks for your response.
