Casusa Posted April 7, 2014 Share Posted April 7, 2014 Hi. I've to make this shutter or where can i find one like this: http://www.google.pt/imgres?imgurl=&imgrefurl=http%3A%2F%2Fwww.perfilis.pt%2Fportadas.html&h=0&w=0&tbnid=JJ51SlVeD40KBM&zoom=1&tbnh=194&tbnw=259&docid=2jepQokfqMpToM&hl=pt-PT&tbm=isch&ei=ao9CU8XJGorx0gWvooDQDw&ved=0CAIQsCUoAA Thanks. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 7, 2014 Share Posted April 7, 2014 Looks fairly easy to make. It's a frame with some angled flats in it unless my eyes deceive me. Quote Link to comment Share on other sites More sharing options...
Casusa Posted April 7, 2014 Author Share Posted April 7, 2014 Hi ReMark. I can do it but if you can resume the commands for the simply way to do it i'de apreciate. Probably i don't do this the easyest way. Many thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 7, 2014 Share Posted April 7, 2014 Make a profile of your frame and the slat and use either Extrude or Sweep. Probably the toughest part is getting the spacing and angle of the slat correct. This can be worked out in 2D. Quote Link to comment Share on other sites More sharing options...
Casusa Posted April 7, 2014 Author Share Posted April 7, 2014 Many thanks. Quote Link to comment Share on other sites More sharing options...
Casusa Posted April 7, 2014 Author Share Posted April 7, 2014 I've a shutter but not with the measures i need, how can i rezyse it? I've attached it. 3D-Shutter.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 7, 2014 Share Posted April 7, 2014 If you built a shutter from scratch why wouldn't you make it the size you need? You could try the Move Faces command . Quote Link to comment Share on other sites More sharing options...
Casusa Posted April 7, 2014 Author Share Posted April 7, 2014 No ReMak, this is one i've found on net, i just want to know if is i possible to resyse it in both axis (x,y). Thsnks. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 7, 2014 Share Posted April 7, 2014 (edited) You easily could have made your own by now. Same advice as previous. Move Faces. If that doesn't work try Offset Faces. What size does it have to be? Is this supposed to be a wood or metal shutter? Are the louvers in your image slanted in the opposite direction than your 3D shutter drawing? One other thing I noticed is it appears there is a space between each louver (they do not touch each other). Your 3D shutter does not have this space. Edited April 7, 2014 by ReMark Quote Link to comment Share on other sites More sharing options...
Dana W Posted April 7, 2014 Share Posted April 7, 2014 I've a shutter but not with the measures i need, how can i rezyse it? I've attached it. [ATTACH]47910[/ATTACH] It is a 3D block. It may be as simple as >> Copy with basepoint, then paste it into your drawing. Then Scale appropriately. By the way, those louvres are drawn upside down. The slats are supposed to protrude at the bottom, not at the top as they are drawn. The slats, as drawn protrude past the frames, and that is also wrong. Quote Link to comment Share on other sites More sharing options...
Casusa Posted April 8, 2014 Author Share Posted April 8, 2014 You easily could have made your own by now. Same advice as previous. Move Faces. If that doesn't work try Offset Faces. What size does it have to be? Is this supposed to be a wood or metal shutter? Are the louvers in your image slanted in the opposite direction than your 3D shutter drawing? One other thing I noticed is it appears there is a space between each louver (they do not touch each other). Your 3D shutter does not have this space. Hi. Measures: One with H=1.10cm W=0.75cm and other with H=1.10cm W=0.50cm Metal shutter, green aluminum . The block is ok like that, doesn't have to be too much detail. Forget the image, that's only an example from google. Thanks. Quote Link to comment Share on other sites More sharing options...
Casusa Posted April 8, 2014 Author Share Posted April 8, 2014 It is a 3D block. It may be as simple as >> Copy with basepoint, then paste it into your drawing. Then Scale appropriately. By the way, those louvres are drawn upside down. The slats are supposed to protrude at the bottom, not at the top as they are drawn. The slats, as drawn protrude past the frames, and that is also wrong. Thanks by the advise. The scale is not proportional. As i wrote before the block is ok like that, doesn't have to be too much detail. Thanks. Quote Link to comment Share on other sites More sharing options...
Dana W Posted April 8, 2014 Share Posted April 8, 2014 Thanks by the advise. The scale is not proportional. As i wrote before the block is ok like that, doesn't have to be too much detail. Thanks. Good luck with your project. Quote Link to comment Share on other sites More sharing options...
CEEinOrlando Posted April 8, 2014 Share Posted April 8, 2014 Keep us posted on your adventure! Quote Link to comment Share on other sites More sharing options...
Casusa Posted April 8, 2014 Author Share Posted April 8, 2014 I made it. Quote Link to comment Share on other sites More sharing options...
