Arch4ik Posted April 10, 2014 Share Posted April 10, 2014 Hey there. I've been trying to customize some things around my CUI, mainly my right click menu so that I can work faster and not hit that pesky erase option. I have set the CUI to the way I liked it, but then when I went to select a single block an option called "Seek Design Content" popped up in between my Modify commands on my right click context menu. I've searched through most of the CUI menu configs and I can't seem to find this specific option to get rid of it. I've posted a screenshot to help with this bizarre occurrence. Quote Link to comment Share on other sites More sharing options...
Dana W Posted April 11, 2014 Share Posted April 11, 2014 Hey there. I've been trying to customize some things around my CUI, mainly my right click menu so that I can work faster and not hit that pesky erase option. I have set the CUI to the way I liked it, but then when I went to select a single block an option called "Seek Design Content" popped up in between my Modify commands on my right click context menu. I've searched through most of the CUI menu configs and I can't seem to find this specific option to get rid of it. It's not so bizarre. The design center is where blocks not existing in your drawing can be found. Thus the contextual connection. Don't know if it will help you customize your CUI but the command to open the design center is ADCENTER. Look for that command in relation to the right click contextual menu, and see what starts it up. Maybe you can nullify it or at least move it. Seems to me it should be the 4th of the top 4 selections. Quote Link to comment Share on other sites More sharing options...
