rock1 Posted April 11, 2014 Share Posted April 11, 2014 I'm using autocad 2012. It has started behaving strangely. When I click on any command, it asks me to select objects. I do so and the command works...so far so good. But, if I click objects first and then click the command, my objects get deselected and AutoCad asks for object selection. This is unusual. After that, everything goes fine as it should. What is causing this and how should I fix it? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 11, 2014 Share Posted April 11, 2014 Type PICKFIRST at the command line and change the setting to 1. Quote Link to comment Share on other sites More sharing options...
zaphod Posted April 11, 2014 Share Posted April 11, 2014 check this setting Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 11, 2014 Share Posted April 11, 2014 check this setting That does the same thing I mentioned. Pickfirst is the variable that controls the Noun/verb selection. Changing the Pickfirst setting to 1 or 0 toggles the Noun/verb selection on and off. Quote Link to comment Share on other sites More sharing options...
zaphod Posted April 11, 2014 Share Posted April 11, 2014 Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 11, 2014 Share Posted April 11, 2014 Me too. Quote Link to comment Share on other sites More sharing options...
rock1 Posted June 20, 2014 Author Share Posted June 20, 2014 Type PICKFIRST at the command line and change the setting to 1. Thanks! That Did it. Quote Link to comment Share on other sites More sharing options...
