donbosco Posted April 11, 2014 Share Posted April 11, 2014 Hi, Recently i joined company who normally used title block sizes A0, A1. This was created by someone years ago. Now i am asked per customer request to provide dwgs in size 11x17, D and E. How do i convert size A1 TB to these or i have to create something new from scratch? Appreciate your help. Thanks. Quote Link to comment Share on other sites More sharing options...
MSasu Posted April 11, 2014 Share Posted April 11, 2014 You may draw the outlines to the required size, while any table may be scaled down with 25.4. An alternative will be to use one from the templates supplied with AutoCAD. Quote Link to comment Share on other sites More sharing options...
donbosco Posted April 11, 2014 Author Share Posted April 11, 2014 Thank you, i will try this asap. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 12, 2014 Share Posted April 12, 2014 You could take your A1 title and half size it as a start this is close to 17X11 420x297 then rescale a little bit to be exact (0.9407 scale), redo the text size so it goes back to being say 1.25mm or 1/16" I work in metric. Do not go lower as you will not be able to read. We draw A1 but always produce A3 as plots except when dwgs are complex and then we get asked for A1, just read as inches size. Quote Link to comment Share on other sites More sharing options...
