sfuoco Posted April 15, 2014 Share Posted April 15, 2014 Here's an example: http://mwcgi.com/wp-content/uploads/2010/10/floor-plan1.jpg You'll notice at the top, there are numbered circles 1, 2, 3, etc. What are their purposes on a floor plan? Thanks! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 15, 2014 Share Posted April 15, 2014 Those are column lines numbers/letters. As column C3 would be the column where the column lines 3 and C meet. Quote Link to comment Share on other sites More sharing options...
sfuoco Posted April 15, 2014 Author Share Posted April 15, 2014 Oh, ok I understand, they're meant to work like the grid on a map. I'm assuming this would be used for larger floor plans? Thanks for the quick answer! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 15, 2014 Share Posted April 15, 2014 Oh, ok I understand, they're meant to work like the grid on a map. I'm assuming this would be used for larger floor plans? Thanks for the quick answer! No problem, yes they are used to work as in the grid on a map. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 15, 2014 Share Posted April 15, 2014 There could also be beams between those columns. Quote Link to comment Share on other sites More sharing options...
Dana W Posted April 15, 2014 Share Posted April 15, 2014 You see that a lot in Florida residential construction too. We have to put hugeomongous structure in houses that have to withstand our storms. Quote Link to comment Share on other sites More sharing options...
