bjenk8100 Posted April 16, 2014 Share Posted April 16, 2014 Hello, I havent been using AutoCAD in a little while and trying to figure something out. I have someone else's drawing that is 24x36 layout. I made a layer for a match line and all looked good at this layout. I went to page setup and created new layout at half size 12x18. When I opened it I cut the scale in half and everything was good except for my line. I changed the layer but it changes the layer in the other layout too. Is there a way to keep different layouts with different scales and layers are different if that makes any sense? Quote Link to comment Share on other sites More sharing options...
bjenk8100 Posted April 16, 2014 Author Share Posted April 16, 2014 i think i use to save as and make the new file at the different page layout. Quote Link to comment Share on other sites More sharing options...
MSasu Posted April 16, 2014 Share Posted April 16, 2014 I would say that this is a normal behavior; adjusting properties of a layer will reflect in all layouts, so starting a new drawing will not be of help. However, on newest releases of AutoCAD, you are allowed to override some layer properties (including lineweight) by layout; just call LAYER command while in a layout and check the VP Lineweight column - adjust it to suit your needs and switch to next layout. For sure, your entities must have their lineweight assigned as ByLayer. Quote Link to comment Share on other sites More sharing options...
Pablo Ferral Posted April 16, 2014 Share Posted April 16, 2014 VP Override its a great option. If you need to do this often, you could set up a new pen table. Quote Link to comment Share on other sites More sharing options...
