samifox Posted April 16, 2014 Share Posted April 16, 2014 hi i want to define 0,0,0 coordinate as 0,390,0. i have elevation view with specific levels values, i want to match it with the ucs so when i acquire a point with "id" i'll get the value i see in the label. one way to do so is , if my elevation is 390 , i should move my geometry to the ucs 0,390,0 , how to do it other way around? how to set the ucs to 0,390,0 without moving the geometry? Thanks S Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 16, 2014 Share Posted April 16, 2014 UCS > Origin? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 16, 2014 Share Posted April 16, 2014 How do you want the XY to be oriented? Perhaps, create line from 0,0,0 to 0,390,0 and the UCS ZA O and click the end of the line. Quote Link to comment Share on other sites More sharing options...
steven-g Posted April 16, 2014 Share Posted April 16, 2014 Or get really complicated and type UCS 0,390,0 enter Quote Link to comment Share on other sites More sharing options...
samifox Posted April 16, 2014 Author Share Posted April 16, 2014 hi as you see , i type "ucs" and than i click the 390 point, now the 0,0,0 of the drawing is actually the 390. i want the xyz to read 0.390.0 when im on that point and not 0,0,0 thanks S Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 16, 2014 Share Posted April 16, 2014 Then shouldn't your coordinate system be origin at world 0,0,0? I don't understand the problem - attach your *.dwg file here. Quote Link to comment Share on other sites More sharing options...
samifox Posted April 16, 2014 Author Share Posted April 16, 2014 here you go if i exe "id" on the point of 390, i want to see x=? y=390 z=? samifox.dwg Quote Link to comment Share on other sites More sharing options...
samifox Posted April 16, 2014 Author Share Posted April 16, 2014 Or get really complicated and type UCS 0,390,0 enter i got the joke but when i click that point? Quote Link to comment Share on other sites More sharing options...
samifox Posted April 16, 2014 Author Share Posted April 16, 2014 ok i set the origin to that point aster that i enter ucs 0,390,0 the id shows 0,-390,0 why is that? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 17, 2014 Share Posted April 17, 2014 I do not do the type of work shown in your drawing, but - I think what you need to do is set the UCS to World and then Move that geometry to the location 0,390,0 But you have a lot of other stuff in the file (some of it very far away) that really confuses me in what I would consider normal workflow for my type of work. Quote Link to comment Share on other sites More sharing options...
samifox Posted April 17, 2014 Author Share Posted April 17, 2014 hi im a constructor, so i get the dwg from the architect, i really dont want to change anything in his structure because this file is subject to updates. what steven offers is good, but for some reason i get negative value $ucs i click in the point of my elevation label $ enter enter $ucs 0.390.0 enter when i lay on the 390 point, the coordinate system reads 0.-390.0 any idea why? thanks Shay Quote Link to comment Share on other sites More sharing options...
nextvkin Posted April 23, 2014 Share Posted April 23, 2014 Offset the line that you want to see as x=0, y= 390,z=0 by -390, use that line to create your ucs. When you id the original line it'll show as what you want. Quote Link to comment Share on other sites More sharing options...
steven-g Posted April 23, 2014 Share Posted April 23, 2014 Indeed I was joking, from your drawing it looks like you need to have the ucs set at different points, depending on the section you are using, I would type "UCS" then pick your base point (the 390 reference line, at its X=0 point), press enter to accept the ucs orientation, and then type "UCS" again this time type 0,-390,0 which will move the origin point to your zero point for that elevation, from there you can draw your lines as though starting from 0,0,0. Quote Link to comment Share on other sites More sharing options...
samifox Posted April 23, 2014 Author Share Posted April 23, 2014 Indeed I was joking, from your drawing it looks like you need to have the ucs set at different points, depending on the section you are using, I would type "UCS" then pick your base point (the 390 reference line, at its X=0 point), press enter to accept the ucs orientation, and then type "UCS" again this time type 0,-390,0 which will move the origin point to your zero point for that elevation, from there you can draw your lines as though starting from 0,0,0. please "reply with quote" steven-g so the context of your post can be understood easily Quote Link to comment Share on other sites More sharing options...
steven-g Posted April 23, 2014 Share Posted April 23, 2014 $ucs i click in the point of my elevation label $ enter enter $ucs 0.390.0 enter OK try ucs click in the point of your elevation label enter enter ucs 0,-390,0 enter or ucs from (type the word "from", before picking a point) click in the point of your elevation label (move the mouse downwards in the negative Y direction then type 390) enter Quote Link to comment Share on other sites More sharing options...
