list box slide
  • Replies 20
  • BIGAL
    4
  • MSasu
    2
  • fixo
    1
  • Snownut
    1
Posted Images
If you want super simple then use a mnu with its inbuilt slide function. You cannot change its look but it does support multiple pages. You just have Menu item group that you pick. Also why not Tool palettes.
Hi Bigal i have a question
***image
**TRENCH
[TRENCH]
[sLD(CGG101,KERB)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG101")
[sLD(CGG102,NATURE)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG102")
**PIPES
[PIPES]
[sLD(SD201,SUBSOIL)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG201")
[sLD(SD202,FLUSHOUT)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG202")
[sLD(SD203,CATCH)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG203")
[sLD(SD204,HOUSE)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG204")
[sLD(SD205,STREET)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG205")
[sLD(SD206,EASEMENT)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG206")
[sLD(SD207,ANCHOR)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG207")
all my slides is in a file c:\Symbol library\sld
How can i write it ??
Hi Fixo how to use this ? I canot understand
slidelib library [ < slidelist ]
dir *.sld /b > mylist
slidelib mlib < mylist
I try something like this but is not working
***image
**TRENCH
[TRENCH]
[c:\Symbol library\sld (CGG101,KERB)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG101")
or
[sLD(c:\Symbol library\sld \CGG101.sld,KERB)]^C^C(openblk "P:/ACADSTDS/CIVIL STANDARDS/CGG101")
A lot of examples in the thread that was linked by Msasu
This sort of thing, using your own custom paths, images, directories, and actions to be preformed, cannot be simply written for you.
You will need to take an honest stab (attempt) to code it yourself, and WHEN you run into a singular issue (error, statement not working, unable to construct statement, etc), then come here and post about it for the quickest results.
Not orders but this is how I usually get by so I'm referring you to the same method :D
The slide library file the slb just needs to live in a location you have defined in your support paths CONFIG FILES "Working Support File Search Path" Add
You dont need the path then. I think the space is screwing it up in "Symbol Library"
not sure if I posted top menu code
***MENUGROUP=STDS
***POP15
**CADLIB
            [LIBRARY]
            [->Stddwgs]
            [TRENCH]$I=STDS.TRENCH $I=*
            [PIPES]$I=STDS.PIPES $I=*
Ok here we are .
I have this list box menu
The sld must be the path of slide icons
The full path is c:\topocad\sld
Don't forget .I have gone to
tools -> options and give the path c:\topocad
***image
**Symbols
[symbol library]
[sLD(arrow,Arrow)]^C^C^P(load"symbols");_arrow
[sLD(north,North)]]^C^C^P(load"symbols");_north
The slide icons is in the sld folder but when i load the menu i can't see the icons
if i write this and coppy my slide icons in topocad file only
***image
**Symbols
[symbol library]
[(arrow,Arrow)]^C^C^P(load"symbols");_arrow
[(north,North)]]^C^C^P(load"symbols");_north
this menu works and see the icons.
The problem is that i want to put my slide icons in the file sld. How can i do it ?
As Fixo previously posted
Ok bottom left click Start
then CMD
then c:
CD\
Cd topocad\sld
slidelib SLD
a new file SLD.SLB should now exist
should now work, if slidelib does not work look for it in c:\program files\autodesk\Autocad 2013 etc and copy to topocad\SLD
In the cmd after C:\topocad\sld i add dir *.sld /b > mylist. And Create a file with name mylist with no extension in sld folder. Then i add slidelib SLD
I take it could not find SLIDELIB I usually copy it to a shorter directory like my c:\acadtemp so I can find it easy C:\acadtemp\slidelib SLD
Use a script to make sld's can do 100+ dwgs in a few minutes.
Open dwg1 Z E Z 0.9 mslide dwg1 close N
Open dwg2 Z E Z 0.9 mslide dwg1 close N
