Add block to polyline
mostafa badran
Hi all,
Can I add block to the polyline as attachment via lisp ?
I want to select all polyline then insert one block at selected polyline .
Thank for help.
test add block.dwg
Edited by mostafa badran
add more details
mostafa,
First and foremost, you need to modify the insertion point of your block
to be at the tip of the arrow.
Second you may use the vlax-curve fuction to get the midpoint of your polylines.
(defun c:test ()
  (while  (setq ent (car (entsel "\nSelect polyline:")))
     (setq d (/ (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent)) 2.0)
           p (vlax-curve-getPointAtDist ent d)
     (vl-cmdf "._insert" "WIRE-TYPE" p "" "" "")
ymg
mostafa,
(defun c:test ()
ymg
Thanks ymg3 for respond, I do not know it is possible or not can you modify lisp to work with ssget function to insert block .
this thread maybe help .
http://www.cadtutor.net/forum/showthread.php?48143-LISP-to-find-midpoint-of-multiple-lines&p=327737&viewfull=1#post327737
(defun c:test (/ d e i p ss)
  (prompt "\nSelect polyline: ")
  (while  (setq ss (ssget '((0 . "LWPOLYLINE")(8 . "00-BT-PA-WIRE"))))
        (setq e (ssname ss (setq i (1- i)))
              d (/ (vlax-curve-getDistAtParam e (vlax-curve-getEndParam e)) 2.0)
              p (vlax-curve-getPointAtDist e d)
mostafa,
You are a senior member, I believe you could do it.
Do study the code and try to understand what is going on.
Mostafa Autocad help is for just that if you looked up ssget under lisp and using selection filters you would have found the answer very quickly. Its part of ssget to understand how to make filter selections and these can be quite complicated. Type Layer Colour Linetype x value to mention a few.
mostafa,
Thanks for your effort,
Thanks for your care to get me learn, I am really try to do it but I am field, then I ask you to do it to learn.
thanks again .:)
font
Ok
BIGAL I know ssget quietly but the missing part is
I am really try to learn thank BIGAL for interest.:)
code
To choose the point with point , you can use that too. It has the advantage that the block can sit where you want. It is not dependent on: the type of entity, layer, color, etc ,
(defun c:BlckIns ()
 (princ "\n   c:BlckIns  :   V  :  18 . 04 . 2014  ;")
 (setq osm (getVar "osMode")  )
 (setVar "osMode" 512)
  (while  (setq p (getPoint "\n  Select Point on Polyline :  < Enter = Stop > ;"))
;;;      (vl-cmdf "._insert" "WIRE-TYPE" p "" "" "")
     (command "_.Circle" p 200)
 (setVar "osMode" osm)
 (princ "\n   c:BlckIns  :  END  ;")
Edited by Costinbos77
mostafa,
At beginning of the repeat loop we are setting variable i to the length of the selection set (repeat (setq i (sslength ss))
Then inside the loop we read each ename that form the selection set, starting with the last one at index i minus 1.
The loop is decremented by 1 each time you go around.
Say your sslength was equal to 5. so you read ename (ssname ss 4)..3..2..1 ad finally 0.
ymg
mostafa,
ymg
thanks ymg3,
quite clear thank you so much.
