sharris_mid_cal_fab Posted April 17, 2014 Share Posted April 17, 2014 Using AutoCAD 2010. While printing a 3D object, some diverging lines won't print. Especially one side of a round pipe. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 17, 2014 Share Posted April 17, 2014 What visual style are you using? Did you change any system variables that might affect the display of lines or edges in 3D models? Quote Link to comment Share on other sites More sharing options...
sharris_mid_cal_fab Posted April 17, 2014 Author Share Posted April 17, 2014 Model space objects are set to Realistic, Viewports are set to hidden. dispsilh is set to 1. Quote Link to comment Share on other sites More sharing options...
nestly Posted April 17, 2014 Share Posted April 17, 2014 A screenshot and a sample dwg file would greatly increase the quality of the help you recieve. Quote Link to comment Share on other sites More sharing options...
sharris_mid_cal_fab Posted April 17, 2014 Author Share Posted April 17, 2014 How do I do that? I've created a PDF. Can I post that? Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 17, 2014 Share Posted April 17, 2014 An actual DWG file would be better. One can be attached to a subsequent post. Start by clicking on the Go Advanced button. There is a file size limit. A PDF doesn't cut it. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 18, 2014 Share Posted April 18, 2014 Press Prtscrn its up on the F keys normally open Paint then paste, clip the image copy only relevant bit needed do a new and paste clipped image, save the image then use the attach image option under Advanced option of the post screens here bottom right. I use a screen capture program saves clipped screen grab. GADWIN. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 18, 2014 Share Posted April 18, 2014 To solve the problem we need the drawing itself. Not a PDF. Not a JPG. Not a PNG. A DWG file. Got it? Thanks. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 25, 2014 Share Posted April 25, 2014 There appears to be nothing in model space other than a reference to the path of the drawing. That doesn't help much. Quote Link to comment Share on other sites More sharing options...
sharris_mid_cal_fab Posted April 25, 2014 Author Share Posted April 25, 2014 ReMark, just figured it out. I had overlapping objects in the model. Thanks. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 25, 2014 Share Posted April 25, 2014 I see. OK. Well thanks for updating us. Quote Link to comment Share on other sites More sharing options...
