Results 1 to 5 of 5
    Senior Member ILoveMadoka's Avatar
    Solidworks 2015
    Oct 2008
    335
    Question Lisp to reorder a column of text?
    Does someone have a routine (or know of a way) to reorder a column of text items?
    ie:
    Line 1
    Line 2
    Line 3
    Line 4
    to
    Line 4
    Line 3
    Line 2
    Line 1
    I have a large table of text that I need to flip the column order.
    Has someone posted something along these lines?
    Is there an Autocad command I don't know about?
    I have had no luck in any of the search terms I have used..
    Thanks for all the help you guys provide...
    Senior Member ymg3's Avatar
    not applicable
    May 2011
    414
    Is it a true autocad table or simply line of text ?
    Post a drawing
    Solidworks 2015
    Oct 2008
    335
    Lee Mac to the rescue once again!!!
    Dynamic Text Alignment v1.6
    http://www.lee-mac.com/dynamictextalignment.html
    I had to jump through some hoops but Lee's program made it all possible.
    Could your next update allow a text column to be rotated 360 degrees instead of limiting it 180?
    (seems that is how it worked)
    I had to rotate the text in place 180 degrees then use Autocad to rotate the entire column 180.
    Awesome! Still quite a time saver!
    Thanks Lee!
    ps: It was all regular text entities
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    I'm glad my Dynamic Text Alignment program came in handy!
    Here is another way to achieve the same result:
    Code:
    (defun c:revtxt ( / e i l s )
        (if (setq s (ssget "_:L" '((0 . "TEXT"))))
                (repeat (setq i (sslength s))
                    (setq e (entget (ssname s (setq i (1- i))))
                          l (cons (list (assoc (if (and (= 0 (cdr (assoc 71 e))) (= 0 (cdr (assoc 72 e)))) 10 11) e) (assoc -1 e)) l)
                (mapcar
                   '(lambda ( a b ) (entmod (list (cadr a) (car b))))
                    (setq l (vl-sort l '(lambda ( a b ) (< (caddar a) (caddar b)))))
                    (reverse l)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  5. #5
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,601
    This prompted me to a slightly different question you have 3 individual columns of text but only want to sort on 1st column wrote a export columns that joins the text into single row then using Lee-Mac's would allow sort. Any one wants it post request here. It was done to export to excel to sort.
  1. Reorder objects
    By gibenner in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Aug 2013, 02:44 pm
  2. dynamic block via no column in multiple text
    By LauKwokFai in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Oct 2012, 01:44 pm
  3. help !! lisp code for quick dimension&column
    By git_thailand in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Mar 2012, 04:35 pm
  4. HELP REPAIR OF LISP Coordinate MORE HIGH COLUMN (Z)
    By namnhim in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Jun 2011, 10:44 am
  5. column lisp
    By wrha in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Jan 2010, 05:08 pm
Tags for this Thread
