Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2013
    Apr 2014
    The Netherlands
    4
    Question See in which file a dwg is inserted as xref?
    Hello,
    Is it possible to see in which files a dwg is inserted in as an xref? In a project I'm working om, there is a lot of 'junk-dwg's'. I must clean up the project-folder, but ofcourse, I don't want to mess up the drawings with xrefs in it that are used. So, if i can see which dwg's are used as xref, I can clean up a lot of unneccesary dwg's in the xref-folder.
    Thanks!
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    You may want to check the Reference Manager stand-alone utility - look for it in Window's Start Menu along AutoCAD.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD┬▓ + PICKFIRST = 3
    Forum Newbie
    AutoCAD 2013
    Apr 2014
    The Netherlands
    4
    Thanks for your answer, but the Reference Manager doesn't work like I need to. I want to 'look up', to see in which other dwg's a dwg is inserted as xref. For all I know, the Reference Manager works 'downwards', so it gives you a list of all the xrefs in a drawing.
    Is there any way to 'look upwards' ?
    AutoCAD 2013
    Nov 2011
    6,045
    You can figure that out using the DESIGN CENTER, I believe rkent posted about doing this a couple months ago, very helpful tip.
    I haven't had occasion to need to do it, but as I recall it involved using the SEARCH function in the DESIGN CENTER to search through entire folders.
  5. #5
    Forum Newbie
    AutoCAD 2013
    Apr 2014
    The Netherlands
    4
    Thank You Dadgad,
    I'm going to try it first thing Tuesday morning, when I'm back in the office
  6. #6
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    How many files are we talking about? Is this something you will need to do on a regular basis? If so, why? Do you have a lot of people with access to the XREF folder?
    File/directory organization/maintenance is necessary for many reasons. If this is just a one time thing then I would suggest you just go through all the XREFing files. You are going to have to do it anyway to verify that any tool that you try worked as expected.
    Instead of trying to cleanup the XREF folder, rename it and create a new one. Open XREF manager in first drawing, then move all the drawings on that list to the new XREF folder, and reload. Save and close. Open XREF manager in next drawing and move all missing XREFs to the XREF folder. Do the same for all the other drawings.
    Drafting is a breeze.
  7. #7
    Forum Newbie
    AutoCAD 2013
    Apr 2014
    The Netherlands
    4
    I think, in total we 're talking about 150 files. This project was divided into 2 different projects: the preliminary design and the final design. Someone has copied all the files from the preliminary design into the folder of the final design without giving it further thoughts of the concequences. And people have worked in both folders since, real chaos.
    Fortunately it is not the normal way of working here, so I hope it is only one time necessary to clean up everything.
    However, the search funtion in the Design Center works for me, so thanks all for helping me.
  1. Inserted xref not showing up
    By mdp198 in forum AutoCAD Drawing Management & Output
    Last Post: 7th Sep 2010, 01:18 pm
  2. Inserted .csv file not plotting
    By grooby in forum AutoCAD Beginners' Area
    Last Post: 19th Aug 2009, 10:15 pm
  3. Xref File name
    By ranassar in forum CAD Management
    Last Post: 30th Oct 2008, 01:59 pm
  4. contour lines show up when xref inserted
    By corinne in forum AutoCAD Drawing Management & Output
    Last Post: 5th Sep 2008, 05:23 pm
  5. Replies: 0
    Last Post: 27th Jan 2007, 12:00 am
