Results 1 to 7 of 7
    Senior Member Vagulus's Avatar
    Vagulus's Computer Details
    Windows 7
    MSI B75MA-P45
    Intel i5-3470
    8GB
    Intel HD
    Samsung Synchmaster 940BW
    Inventor 2014
    Jul 2013
    Perth, Western Australia
    176
    Default Tutorial 101 - cannot create centrepoint
    In http://www.cadtutor.net/forum/showth...8-Inventor-101 I am at posting 33 and I came to a halt.
    I can't draw a point on the flat, and I don't see any midpoint on the created line.
    What do I have wrong?
    "Insanity is doing the same thing
    over and over again
    and expecting different results."
    Albert Einstein
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,719
    Right click on Sketch3 and select Edit Sketch (if not already in sketch editing environment).
    Select the sketch point tool.
    Click the midpoint (green dot will appear) of the line.
    Windows 7
    MSI B75MA-P45
    Intel i5-3470
    8GB
    Intel HD
    Inventor 2014
    Jul 2013
    176
    Oooops! Mea Culpa! I forgot to mention that I am using Inventor 2015.
    I don't get any centrepoint showing.
    over and over again
    Albert Einstein
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,719
    I opened your file in 2015.
    The image I posted above is from 2015.
    The image you posted is from the other end of the Ribbon than the image I posted.
    Of course if you want to create a sketch point need to be on the Create tab as shown in my image.
    I recommend you sign up for a class.
  5. #5
    Windows 7
    MSI B75MA-P45
    Intel i5-3470
    8GB
    Intel HD
    Inventor 2014
    Jul 2013
    176
    Thanks JD
    Unfortunately, Classes are beyond my financial reach. Perhaps they won't be, on day, if I can get a grip on Inventor.
    You cannot understand how much your help is appreciated.
    I am sure there are many who echo that comment.
    over and over again
    Albert Einstein
  6. #6
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,719
    So, did you figure it out?
    The Point Format tool at the other end of the ribbon is for toggling a Point to a Center Point or a Center Point to a Point. Try it! Select the endpoint of a line and then click that tool or select a Center Point and click that tool. At some point (pun intended) as I continue the Tutorial - we will see the point of toggling the style of a point.
  7. #7
    Windows 7
    MSI B75MA-P45
    Intel i5-3470
    8GB
    Intel HD
    Inventor 2014
    Jul 2013
    176
    I am up to my armpits in something else at the moment.
    I'll get back to you.
    over and over again
    Albert Einstein
  1. Tutorial: Create a DWF file
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 28th Jan 2008, 02:11 am
  2. Tutorial: Create a visual style
    Last Post: 21st Oct 2007, 07:42 pm
  3. Tutorial: Create attributes
    Last Post: 27th Aug 2007, 12:01 am
  4. Tutorial: Create a custom command
    Last Post: 13th Sep 2006, 12:40 pm
  5. Tutorial on how to create a swagged curtain
    By Spacepig in forum Tutorials & Tips'n'Tricks
    Last Post: 6th Jun 2006, 12:56 pm
Tags for this Thread
