Problem in Isometric Views!!!
alijahed
Hi All,
I am experiencing an interesting problem in Inventor!!!
Have you noticed when you measure the angles on your isometric views it is wrong! Instead of being 60 and 120 degree it's got a funny dimensions!!!
Please see below and the attached files.
Part1.zip
  • 10 months later...
I still have this problem unsolved!
To me it is a big problem. Just draw something in Inventor then export it to dwg file to see.
Try edit view. select the change view orientation icon, select the isometric view corner on the view cube, then select Finish Custom View. See if that corrects your drawing view.
As noted on the AutoDesk Forum, the problem is with the projected ISO views.
If the baseview ISO Top Right is chosen, then you get nice square angles.
This isn't a big issue for me, but I find it interesting.
